3 members (TUTS 59, Otto Skorzeny, klhansen), 108 guests, and 3 robots.
Topics128,232
Posts1,057,817
Members48,477
#1613807 10/22/2026 10:00 PM
Question, can a 302 block accept a 4.0 sleeve with a 1/8” wall thickness, this will require the cylinder to bored out to 4.253” any concern with exposing the coolant passage?
Dave1234 #1614053 10/26/2026 8:15 PM
I guess this the wrong forum for these technical questions ,maybe I should post on the inliners forum.
Dave1234 #1614057 10/26/2026 8:31 PM
Dave, boring that much sounds scary, to ignorant me.
Maybe our experts are still mulling this over.😳
What is the reason you are sleeving this 302?
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Dave1234 #1614063 10/26/2026 9:36 PM
The only time I use a 1/8" wall sleeve is if there's a hole in the cylinder wall. Yes, a 302 will probably handle a sleeve that thick, but a 3/32" wall sleeve will accomplish the same fix with less material being removed from the block. That only requires boring the block to 4 3/16". I usually bore for about a .001" press fit when installing sleeves and cold soak the sleeve in dry ice and alcohol before installing it. I've been doing it that way for a little over 40 years.
Dave1234 #1614268 10/29/2026 10:12 PM
I bored the cylinders intending to use sleeves with a 3/32 wall thickness, however one cylinder did not clean up.
Think I have a plan, I have ordered a 1/8 wall sleeve, and will turn the od down on the lathe.
Thanks for the replies.
Dave1234 #1614290 10/30/2026 1:25 AM
It shouldn't matter if the cylinder didn't clean up when bored for the sleeves (I think that's what you're saying.) Unless there's a gaping hole in the bore, the sleeves will take care of minor imperfections.
Dave1234 #1614344 10/30/2026 7:15 PM
Interesting, as I am new to installing sleeves..
I scoured the forums as well as YouTube, looking for advice.
Regarding the interference fit, there are a wide range of methods. Some recommend boring the cylinder .001” under size, the manufacturer of the sleeve “Melling” recommends up to .005” on a large sleeve.
Some just pound then in.
Some use a press, some warm the block and freeze the sleeves. I developed my own method, so far so good.
Dave1234 #1614430 10/31/2026 6:27 PM
Years ago salvage liners were quite popular. We ran quite a few of them. We always used 3/32 sleeves. We used them for everything from cracked cylinders to big gouges in the cylinder. We just made sure we had a good press fit. Especially at the top and bottom. The government sleeved a lot of 302 engines back to standard. I have one of them torn down at the moment. It is nice to have them because standard pistons and rings are much more available. Before I get back to a GMC I need to get an old Y-Block out of the way. It is border line junk .006 to .008 over. I am debating as to use old Continental file to fit rings and knurl the pistons or junk it.
Dave1234 #1614432 10/31/2026 6:37 PM
Back when I was building "mini-stock" race car engines based on the Ford 2300 CC 4 cylinder overhead cam engine, the sneaky trick was to bore the original cylinder walls completely away and install 1/8" wall 4" diameter sleeves. We ran a very light weight Chevy 350 piston and H beam connecting rods. As long as we could get a good press fit at the top and bottom 1/2" of the block, the engines ran just fine. We put a 1/2" thick layer of high temperature epoxy at the bottom of the water jacket to help seal coolant out of the crankcase. Of course, when one hand-grenaded at 9K+ RPM, there was nothing left to rebuild!
Dave1234 #1614481 11/01/2026 12:02 AM
Good to know that it’s Not The End Of The World if you expose the coolant passage. Some of us err on the side of caution.
As I have said before there is alot of information out there about sleeving cylinders, you have to make a judgement call, particularly when you are learning.
Dave
Dave1234 #1614482 11/01/2026 12:47 AM
Just remember to use a good coolant if you expose the liners to coolant. They are more prone to rust than the cast iron block.
Dave1234 #1614487 11/01/2026 1:20 AM
It can be very educational to take a sawzall to a junk engine block and see just how thick the cylinder walls actually are in different areas.
Dave1234 #1614494 11/01/2026 2:19 AM
Thats why it concerned me when I discovered the engine in my wrecker was .060 over. I went ahead and cut the ridge, honed it, knurled the pistons a little and called it good. It has been running like that for 15 years. The irony is about a year after I built it, I found a 371 Olds which is the block GMC used with standard cylinders and almost no ridge. I bought it for a spare, but I have never used it.
Dave1234 #1614599 11/02/2026 4:52 PM
I was tempted to buy one of those tools that measures wall thickness, in this cylinder wall thickness….. until I learned the price of one.
