0 members (), 68 guests, and 3 robots.
Topics128,244
Posts1,057,714
Members48,474
Where might I find info on what type (fine/coarse thread, size, length, etc.) of screw or bolts go where on 235 engine, sm420 4 speed trans, and 3100 body? Or is there anything that shows that? Any info would be very much appreciated.
S2
Stewart2
1955.1 3100
Both Owner and P/U have lots of miles, lots of history and need LOTS of TLC
Jack of several trades and experiences; Master of none
S2 - That info is found in the Chevy Master Parts Books, but not always an easy read and find process. You can find the vast majority of the info related to your Chevy 1955.1 3100 in the following free on-line books:
1929-54 Chevrolet Master Parts and Accessories Catalog
1929-57 Chevrolet Master Parts and Accessories Catalog
Many specific bits of hardware are listed in the individual major item sections of the book, like engines, transmission, etc., but there is also a combined section of the books called Standard Parts Listing (this one from the 1957 Book) that provides further specification details for common hardware items that is often not included in the part description in the major component sections of the books.
Take a gander at these and if you need to, come back and ask more questions and we'll try our best to help you out with more info. smile
~ Dan
1951 Chevy 3 window 3100
You'll find very few fine thread bolts on our trucks. A couple that come to mind are the door hinge bolts (3/8-24) and the engine mount to frame bolt and nut set (don't recall the size, but they're bigger than the door hinge bolts. Everything that screws into cast iron will be coarse thread.
BTW, the bolt part numbers in the FAM don't go anywhere that I've found, as the part numbers likely changed too many times. I've been down that rabbit hole a few times. Unfortunately the FAM #'s don't match up with those in Dan's Standard Parts Listing
Stewart,
What you are asking for may not be available in print, but what is available is a bunch of guys on this site who do know what bolts go where.
My suggestion to you is, as you begin the assembly process, come back in and ask specific questions about what you will be assembling at that time. I am sure that you will receive the information that you will need.
Thank you, guys. for the inputs. I was thinking about using new bolts bought from a hardware store instead of paying the high price that the retailors charge + shipping. I have like 85% of the old bolts but like an idiot, I didn't label them. I really do appreciate your help.
S2
Stewart2
1955.1 3100
Having recently assembled my truck, I may be able to help with ID'ing what bolts go where. Although you may have to ask before memory loss sets in. I have misplaced things I've set down a few minutes prior to looking.
What bolts will you be installing first?
We can start there.
It can be just like eating an elephant.
One bite at a time.
It seems to me the bolts that hold the steering box on are fine thread. All but 1 of them. The one that threads up from inside the frame that threads into the box. I replaced mine with ARP bolts and weld nuts because I'm boxing the frame. I also bought a bumper to bumper stainless bolt kit for my 53 3100 that I could reference for you.
U
U Offline
Wow! I didn't know they had that. Looks like you have plenty to keep you busy this summer.
~ John in Utah
Here We Go
Follow in his DITY Bay
You may be right about the steering box bolts being fine thread. I do know the one that screws up into the box is coarse thread. If you're using stainless steel fasteners, be sure to use anti-seize on them. Especially any that are fine thread. Stainless tends go gall when the nuts and bolts are threaded together and ruin them. But be careful that you don't get any on you.
Good advice. I put something on just about every bolt. Anti-seize, blue, red, or green Loctite. I use the little sticks or tubes of anti-seize and Loctite when possible. So easy to use. Especially the anti-seize. The jar with the brush is a mess.
Moderated
Moderated
I have a general question about bolts on my 1949 216. This is my first post and kind of a goofy question. The bolts for my thermostat housings are grade 5 3/8" x 1". I can purchase replacements from multiple suppliers. But the head height on my original bolts is much taller. Replacements show a head height of 0.234" where the originals measure about 0.285". I really like the look of the beefier head height. Are there suppliers for these vintage style bolts, or should I just not worry about that and replace with the newer style?
My truck was a farm truck its entire life and was my Dad's. It's condition tells its story, and I am replacing what it needs to get it backroads worthy.
Jeff
Jeff, I doubt that any of the vendors carry that type of bolt with the taller heads. If you really want some of them (are you going to Concours shows with your truck,) I'm sure that if you post an ad in the Swap Meet, that one of our members could come up with some for you.
Check with McMaster Carr to see if they have the bolts you need.
Another option is Mr G's fasteners in texas. That guy has every kind of automotive fastener ever made. And he has life size pictures on his website to compare.
Mr. G's Enterprises Automotive fasteners, of all types
5613 Elliot Reeder Road
Fort Worth, Texas 76117-6013
817-831-3501 or 817-838-3131
https://mrgusa.com/
1950 Chevrolet 3100 (Ol' Roy)
