Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Jon G, Dennys28, Uncles51, texas46), 113 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
#1614328 10/30/2026 4:04 PM
Crusty Old Sarge
Crusty Old Sarge
I have 2 Carter YF carburetors on hand and wondering if one series is preferred over the other. I am wanting to rebuild both, swap one for my current Rochester B with possiblly selling the second. The numbers are pictured below.
Carter YF 1
Carter YF 2
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Not sure it helps, but the 964S is for a 216. That's what I have on my truck and it does a good job. With the lower series number, the 787SB is likely also for a 216. Neither probably not the best one if it's going on a 235. The mounting hole spacing on the 964S is smaller than on a 235 manifold and won't physically fit. Jon (carbking) should know and may weigh in with more info.
Crusty Old Sarge
Crusty Old Sarge
These carburetors were on a dual Offenhauser manifold I acquired a while back. I have no idea what they were originally on just that they weren't a matched pair.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Carburetion specialist
C Online: Content
The 787s was the first production of the YF 216 replacement; the 964s was a later upgrade for the 216.
Both will work; the 964 MIGHT work slightly better.
Either is superior (opinion of the writer) to the Rochester.
Jon
The Carburetor Shop
