| | | Forums66 Topics128,236 Posts1,057,631 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,207 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,207 | Those two at the bottom of the bore would actually be the easiest to get moving, with the geometry of the crank position. Turning force on the crank would be multiplied many times with pistons at BDC or TDC. But the others at mid-stroke would have the least mechanical advantage and would keep the crank from turning. Once disconnected from the crankshaft, each piston is an independent problem and usually will move without too much problem. On mine, even that one that was really stuck moved until it got to the top of the bore where there was too much rust and crud. I suppose I could have wire brushed the bore like you did and had better success, but I got it done with the brute force method.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2022 Posts: 146 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 146 | I do believe this will end with brute force. Im just not to that point yet.
Rock49 aka C-Rodg work in progress 1956 Chevy 3100 261 engine | | | | | Joined: Feb 2004 Posts: 29,896 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,896 | I Of course the engineer who designed the bell housing attachment was clearly a Bond villain. Sneaky trick here- - - - -use about a 3/4" or 1" diameter hole saw and poke a few holes in the bell housing adjacent to the clutch bolts you can't reach. Then use a universal joint socket to remove the bolts. That just leaves a few "clutch cooling holes" in the bellhousing, and it can be reused. You can even plug the holes with rubber expansion freeze plugs if you choose to do so. Jerry
