6 members (Greg_H, Chip O, Barnfind49, dt235sd, KEVINSKI, klhansen), 109 guests, and 2 robots.
Topics128,237
Posts1,057,662
Members48,473
Page 2 of 2 1 2
Rock49 #1614243 10/29/2026 4:37 PM
Those two at the bottom of the bore would actually be the easiest to get moving, with the geometry of the crank position. Turning force on the crank would be multiplied many times with pistons at BDC or TDC. But the others at mid-stroke would have the least mechanical advantage and would keep the crank from turning. Once disconnected from the crankshaft, each piston is an independent problem and usually will move without too much problem. On mine, even that one that was really stuck moved until it got to the top of the bore where there was too much rust and crud. I suppose I could have wire brushed the bore like you did and had better success, but I got it done with the brute force method.
Rock49 #1614247 10/29/2026 5:02 PM
I do believe this will end with brute force.
Im just not to that point yet.
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Rock49 #1614259 10/29/2026 7:15 PM
Originally Posted by Rock49
I Of course the engineer who designed the bell housing attachment was clearly a Bond villain.
Sneaky trick here- - - - -use about a 3/4" or 1" diameter hole saw and poke a few holes in the bell housing adjacent to the clutch bolts you can't reach. Then use a universal joint socket to remove the bolts. That just leaves a few "clutch cooling holes" in the bellhousing, and it can be reused. You can even plug the holes with rubber expansion freeze plugs if you choose to do so.
Page 2 of 2 1 2
