1 members (1 invisible),
111
Mod | | | Forums66 Topics128,261 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 267 Custom Title | | Custom Title Joined: Nov 2004 Posts: 267 | 3600 disc brake conversion question. I'd like to do this conversion on my '49 3/4 ton. I am already using the Dexstar 16" wheels on my truck. Does anyone happen to know which of the conversion kits will clear these wheels? Sid Drapal's kit states "you may very well need a disc style wheel". Any advice appreciated.
49 Chevy 3600 65 Chevy K10 66 International 1300 dually 4x4 46 Ford 1/2 ton 76 Tucker Sno-Cat 1642 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Oct 2021 Posts: 7,030 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,030 | Aren't the Dexstar wheels made for trailers?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Nov 2021 Posts: 1,444 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,444 | I have a 1950 3600 converted to disk brakes on the front but I am not running those wheels so I can't provide any clear answer. I think with wheel back spacing information you may be able to at least ask the disk brake conversion source if their kit would work. | | |
