Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
9 members (crenwelge, 51sub, MickeyP, Otto Skorzeny, Thom75, TUTS 59, tclederman, JayDP, 1 invisible), 166 guests, and 5 robots.
Topics128,284
Posts1,058,531
Members48,490
B Online: Content
Looking for a 66 era overdrive saginaw 3 speed with the 7 bolt sidecover. I would also be interested in just the borg warner OD rear section to add to a normal saginaw 3 speed. I already have the governor and solenoid. Just need a whole trans or the hard parts to convert one. Thank you.
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
You may want to reach out to Cosmo, he is pretty knowledgeable on these and has supplied an few in the past.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I did some web snooping and found this ad for a Saginaw 3 speed overdrive in the Tri Five Marketplace ads.
You'll have to join up to be able to contact the seller as I couldn't find any direct contact info in the ad. frown
Preliminary search of FB Marketplace done, but only scratched the surface on that look. Will try to see if I can locate anything else with a deeper look. wink
Best of luck with your search! thumbs_up
~ Dan
1951 Chevy 3 window 3100
I got a 4 bolt side cover I just pulled that I will never use. SM-319
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
B Online: Content
I joined the group but cant PM or reply on the for sale section for 30 days.
B Online: Content
I have one in truck currently and a spare one for parts but im sick of the old 3 speeds popping out of 3rd. Seems like anytime i use them they are a annoying problem.
Barnfind49 - You're at full 'Bolter status so free to PM "Cosmo" or any other unmoderated 'Bolter. wink
Have at it sir as there's no 30 day wait period. smile
~ Dan
B Online: Content
I meant the tri-five forum listed above not here hahaha.
1 Offline
B Online: Content
That one in the pic above is a OD trans but its not GM. Possibly a ford/merc trans looking at the front hole spacing.
Ah, the little light bulb overhead just illuminated - LOL! grin
The good news is there hasn't been a lot of interest in the ad thread there, so a good possibility it could still be available after the "pause".
I'm still looking and will post other leads as I can. wink
~ Dan
1 Offline
Is this a good one for you?
https://www.facebook.com/marketplace/item/862383496132926
GM Chevrolet 3 speed Overdrive. Studebaker?
$150
B Online: Content
Yea thats not GM either. I’ll try to post a pic of a 7 bolt saginaw OD.
Barnfind49 - From 1964-66 (and perhaps later?), Chevrolet offered an optional Borg Warner T-89 "heavy duty" 3 speed with overdrive in the pickup truck line.
I came across this ad that looks like it's offering a T89B that would also fit your application if you can't find a Saginaw 3 speed OD equipped transmission. The picture shows a 1968 casting date on the unit.
At just $100 asking price, it sounds like a great deal. The ad does say "door pickup" and indicates it's in Nashville, Michigan, so maybe a long roadtrip needed to capture this one.
I'll keep looking for a Saginaw in case this won't work for you either. wink
~ Dan
B Online: Content
Yea thats not GM. Looks chrysler. The input shaft is more centered on a GM and I can see from the 1 pic the pattern to bellhousing is wrong.
1 Offline
https://www.facebook.com/marketplace/item/2044564526198952
1960’s Chevy/ GM
Manual 3 speed with OD
Transmission
Out of 60’s Chevelle
$650
1 Offline
B Online: Content
Thats the correct one above with the OD. The next one is just a non OD t-10. My only issue is it just literally couldn’t get any farther away from me and I wouldn’t be interested trying to get it here at that price with shipping on top.
Barnfind - Being that you're in CT, this is maybe also too far out to be worth your while, but I found this Saginaw 3 speed w/OD in Fairmont, MN. As noted in the original ad, it is missing the solenoid.
Asking price is decent at just $200, but a trip half way across the country may be more of a road trip than you want to put into it.
~ Dan
https://www.facebook.com/marketplace/item/1106060128831236
I don't know about. I happen to see some of these in NH area. Happy to pick something up if you find it around up north. I frequent Windham ME.
You said 4 bolt cover. Are you not in market for SM319 should it be available?
~ HB
1962 Chevrolet C10
1962 Suburban
https://www.facebook.com/marketplace/item/1317667853031240
Not listed as OD, but I think I recognize it as OD
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone - He's looking for the later Saginaw 7 - bolt side cover 3 speed OD unit like this one below that were found in mid 1960's Chevy cars and trucks. wink
Both of the ones you posted are the SM319 earlier 3 speed OD transmissions. Thanks for posting those though, as it may be helpful to other 'Bolters looking for the earlier OD units. thumbs_up
~ Dan
Yes - not sure why I thought 4 bolt cover
~ HB
1962 Chevrolet C10
1962 Suburban
B Online: Content
Got a really nice one today. Thanks guys. 👍
Glad to hear you scored what you have been looking for! thumbs_up
Thanks for coming back and reporting. I've marked the ad as "Found" and will leave it up for today so anyone watching can share in your success, then will send it to the big round file in the sky later. wink
~ Dan
