Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (texas46, Jon G, Dennys28, Otto Skorzeny), 101 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
#1172915 07/07/2016 5:56 PM
Last fall I tried to Sneaky Pete & Chinese finger trap in a rear main seal W/1941 235CI engine in truck. No Go! A well meaning friend of a friend shows up declaring "I've done hundreds of those". 6 hours later he says I'll be back in 3 days with a guitar string, haven't seen or heard from him in 9 months.
I've since pulled the engine to do this right and glad I did because I've found a bunch of really ugly stuff.
Here's the rub "friend" has my rear main cap bolts.. I Pulled mid & front cap bolt...not the same size. My supply of big bolts is limited so I can't find the size I need to buy. Cannot find the specs on these anywhere nor any parts place that claims to have them.
If anyone knows what size bolt I need or where I can get them I would be grateful for the info, or If you have 4 of these I would be more than happy to buy them from you.
At this point all I know is they need to be about 2 or 2/14 inches long..
Thanks for the help
Darwin Shilling
PS He has my bolts, but I have his digital torque wrench cool
This post probably needs to be in the "parts wanted" forum, but I can offer a little guidance on what not to use. Those bolts are 1/2"-13 thread Grade 8, so don't try to substitute something from the local hardware store. You'll need to have at least 1 1/2 diameters of thread engagement, or 3/4" minimum thread engagement into the block. If you can't find original-equipment bolts, try somewhere like Fastenal for slightly over-length Grade 8 replacement bolts and adjust the thread length to suit the situation.
Jerry;
Thanks a bunch for the info. I did quick search on the web and lo and behold I found several sources for those bolts using the description you gave me. I saw ARP & Summit Racing. They are a tad pricy but I don't want any junk bolts. I sure don't want to do this again.
Now that know what I need I'll try the Parts Wanted Forum just on the odd chance.
Thanks again
Darwin
Another source you might give a try is your local John Deere dealer. I had an issue with a bad main cap bolt on the #4 cap, the machine shop I use suggested trying there. Turned out that some models of John Deere engines use the same bolts at a 235 Chevy.
Bill Burmeister
Found some NOS bolts!!
thanks guys
Darwin
thumbs_up
Bill Burmeister
Wow! In my 235 engine teardown I’ve found that three of the #4 caps had three stepped bolt and one non- stepped bolt. This old response helps me resolve the cap bolt mismatch I have. I know that Tractor Supply carries grade 8 bolts I need if not here in College Station there is a Bolt & Nut store that should have them.
Just a quick clarification- - - - -the first three main caps have two bolts each, and those bolts are 9/16" diameter. The rear cap has four bolts, and they are 1/2-13 thread. Replacing bolts is possible, but always use Grade 8 fasteners when you do. If you can't find what you need at Tractor Supply, try Fastenal or McMaster-Carr. I've also replaced bolts in high-load areas like cylinder heads and main bearing caps with studs.
