| | | Forums66 Topics128,223 Posts1,057,522 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 716 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 716 | Hello all,
I'm at the end of a 12v conversion on my 3600 and I was wondering if anyone had a wiring diagram that included the heater/defrost motors in it? I have two variable switches and two motors in the unit itself. I haven't added in in-line resistors yet and that was next on my list, however the new 12v mechanical flasher socket seems to have a loose wire. When I wiggle it with the engine running, both heater motors turn on. This seems impossible since both switches for them are in the 'off' position, but that's what's happening. I just want to chase the heater wires back to make sure they are correct. I didn't have any issues like this with 6v, so this seems pretty odd to me.
Thanks! | | | | | Joined: Jan 2022 Posts: 2,503 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,503 | The '48/'49 Chevy truck wiring diagram I just pulled from The Old Car Manual Project doesn't show the heater. Must have been an option.
Because of the "2 fan motor" heater/defroster you have I'm guessing your 12 volt conversion wiring system is aftermarket. Don't you have a diagram?
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jan 2016 Posts: 716 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 716 | This might be a Canadian thing or dealer installed. I guess there won't be any diagrams. Would it be best to wire this to the aux connector on the light switch? | | | | | Joined: May 2015 Posts: 11,195 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,195 | That's what I would do. Tie the feed for the two switches to the aux terminal of the ignition switch.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Two 12v fan motors will pull quite a bit of power, our school bus fleet at work runs 20 amp fuses for each two motor heater using 14 gauge wire. The wires are quite long so the big wire is needed. They use every bit of the 20 amp fuse, just a little corrosion at the connection will knock out a fuse or trip the circuit breakers. These are likely bigger motors than yours.
If you will be running both motors at the same time, I would use a relay with a heavy wire off the amp gauge as a relay feed, then use the ignition source for the switch to turn on the relay. Powering off the light switch could leave you in the dark if running lights, defrost, and heat all at once. The light switch should have a built in circuit breaker designed for the lighting load, adding in two motors could put the amp load too high for the breaker. | | | | | Joined: Jan 2016 Posts: 716 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 716 | I don't drive in winter and have never opened the valves to allow coolant to flow into the heater core, so these are more for show and the defrost is likely the only one I would ever use. That being said, I never had an issue with them before the conversion. The blue-wire from the three prong flasher socket seems to be tripping the fans to come on. Any idea how this could happen? | | | | | Joined: May 2015 Posts: 11,195 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,195 | The blue-wire from the three prong flasher socket seems to be tripping the fans to come on. Any idea how this could happen? Sounds like you have a short between circuits (insulation gone from both wires and the copper touching.) A rewire should fix that. Joe's idea of using a relay to isolate the heavy load from the ignition switch is a good one. Pretty easy to do. If needed you could run a separate heavy gauge wire from the Starter terminal (with a fuse) to the relay, but the Amp gauge as a source should work OK. If you're still running the 6V wiring, the gauge should be good, as using 12V on the same load originally run on 6V only draws half the amps.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,503 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,503 | Seeing as how a 48 Chevy truck didn't leave the factory with turn signals, it will be hard to diagnose this problem without an up to date wiring diagram.
| | | | | Joined: Jan 2016 Posts: 716 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 716 | Well, the heater fans have old cloth covered wiring and I'd be surprised if they weren't original or a dealer add-on. The fans are both wired to the ignition switch. The 7 wire signal switch seems to be wired correctly, with black/blue going to the flasher relay. Power to the relay from the aux on headlight switch. Problem is all terminals on the flasher have 12v (or about 9 when it lights the signal lights back and front. ). But no flashing. It was working previously for a bit when running but now the relay doesn't move. It did say it was for LEDs but maybe that wasn't correct. Also, the little indicator bulb in the signal housing doesn't seem to get power either, which is the blue wire. I'll try picking up another flasher, but I don't know where to go from there if it gives the same result. | | | | | Joined: Jan 2022 Posts: 2,503 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,503 | Some of the LED specific 3 prong flashers have a separate ground wire for the electronics inside the can. Any chance yours is that way?
If you are reading 9 volts on the wire between the flasher and power with a regular (not electronic) flasher you'll never get enough current thru the bi-metallic strip to heat it up and make the flasher work. As a troubleshooting step, disconnect the flasher power wire from the headlight switch and hook it directly to the ammeter + side to see if the flashers work there
| | | | | Joined: Jan 2016 Posts: 716 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 716 | Well, I have seen the flashers with the ground wire and I assume those are for low-voltage LEDs. I just swapped out my rears for incandescent and it flashes as it should. The indicator light in the signal switch still doesn't work though but I've gone this long without it, so I guess I'll live. For the heater fans, it looks like it was a loose wire causing them to come on. I still have to grab 12v bulbs as they are illuminated switches and put the resistors inline. Since I have two fans, I'll probably look to mount the resistors to a piece of aluminum or something and hand under the dash. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Better yet, mount the resistors inside the air ducts of the heater to keep them cool. All muti-speed resistors packs are mounted in the air stream as way to cool them, might as well follow them.
If you want LED tail lights / brake lights, install a 1157 bulb and socket up in the frame rail out of the weather and out of site to create a load on the flasher, the LED's will then work as they should. #2357 is a incandescence bulb with the same tail tail light as a 1157, but a brighter brake light. Paint the inside of the tail light white and do away with the LED's. #2057 is a Halogen version of the 1157, they get way hot, so you need glass lens. They will melt plastic.
| | | | | Joined: Jan 2016 Posts: 716 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 716 | That's a good idea for mounting the resistors, might as well use the heat they produce. My tail lights are all LED, just the signals in the housing are incandescent. I can live with that. I just took it out for it's first drive after the 12v conversion and I noticed two things. My gas gauge is on empty (not related to pump prices ;)) Did I get the runtz in incorrectly? Also, my Ammeter never actually goes to the charge side, even on the highway. Is this something I need to adjust in the voltage regulator? | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | The amp meter should be right at zero or very slightly on the + side. The alternator is putting out just what is being used, no more or no less, so the gauge stay centered. Mine will show plus charge for a short while right after cranking it after setting for a week or so, after that it's centered.
Gas gauge needs to have 6 volts going into it, and the fuel sender needs a really good ground wire right to the sender. The tank is not a good ground. I ran my ground wire all the way back to my main ground stud I installed when making my wire harness. Fact each light is grounded that way also, I don't like chasing ground issues! Use a jumper wire from sender to frame ground or to the battery post as a test, if it still doesn't work, check input voltage at the gauge. | | | | | Joined: Jan 2016 Posts: 716 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 716 | Thanks, the gauge was working just fine before the runtz resistor. I think since it's on empty it might just be a bad ground, so I'll check that out first. | | | | | Joined: Jan 2022 Posts: 2,503 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,503 | Assuming the gauge is getting the proper voltage from the Runtz, an "always empty" indication is caused by the other wire that connects to the sending unit on the gauge being at ground all the time.
Troubleshooting is fairly simple. With the key on, half a tank or so of gas and the gauge showing empty:
Remove the wire from the center of the gas tank sending unit. If the gauge now reads full, the sending unit in the gas tank is bad.
If the gauge still reads empty... Remove the wire from the back of the gauge that the Runtz is not attached to. If the gauge now reads full the wire between the gauge and the sending unit is touching ground somewhere.
| | | | | Joined: Feb 2019 Posts: 4,517 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,517 | Should Bill’s quick troubleshooting tip not work, there is a troubleshooting “Tech Tip” in the Electrical Forum that may help here.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
