0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2026 Posts: 74 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 74 | Question, can a 302 block accept a 4.0 sleeve with a 1/8” wall thickness, this will require the cylinder to bored out to 4.253” any concern with exposing the coolant passage? | | | | | Joined: Mar 2026 Posts: 74 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 74 | I guess this the wrong forum for these technical questions ,maybe I should post on the inliners forum.
| | | | | Joined: Jul 2018 Posts: 282 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 282 | Dave, boring that much sounds scary, to ignorant me. Maybe our experts are still mulling this over.😳 What is the reason you are sleeving this 302?
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | The only time I use a 1/8" wall sleeve is if there's a hole in the cylinder wall. Yes, a 302 will probably handle a sleeve that thick, but a 3/32" wall sleeve will accomplish the same fix with less material being removed from the block. That only requires boring the block to 4 3/16". I usually bore for about a .001" press fit when installing sleeves and cold soak the sleeve in dry ice and alcohol before installing it. I've been doing it that way for a little over 40 years. Jerry
