Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (greenie-reddy, dt235sd, frogfarmer, pauld, Bill Hanlon), 116 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
Page 2 of 2 1 2
I
I Offline
Originally Posted by Gdads51
Love the progress and will celebrate with you from afar. Neat to continue the "Moon Eyes" theme inside to the shifter handle. thumbs_up
Thanks, Dan! Your shared enthusiasm is much appreciated.
I did want to continue the Mooneyes theme, but also wanted to keep it a bit subdued, hence going for the black ball with the eyes, rather than their standard yellow.
Plus, it feels better in the hand than did the motorcyclist skull knob.
~~ Konstantine
1962 Grumman Olson Kurbside/Chevy P30
Follow in the DITY
I
I Offline
Originally Posted by Otto Skorzeny
Konstantine, take a look at this shift boot in another thread. I think it might be a better choice than the round peg in the square hole situation you have now.
https://www.stovebolt.com/ubbthread...5167/floor-mats-for-4-speeds#Post1615167
Hi Otto.
Thanks for that link. Interesting. The boot I put on is a direct replacement of what came off the vehicle, so I assumed it was the correct boot for it. It even had cutouts underneath for the mounting studs to sit in.
I'm wondering now if what was on there was an incorrect replacement at some point in its life?
~~ Konstantine
Follow in the DITY
O Online: Content
Prolly the only boot the previous owner could find at the time. Grumman surely wouldn't have let the vehicle out of the factory with such a jerry-rigged shifter boot that doesn't cover the hole in the floor.
The round boot may have been the one used for a different application, like a pickup truck or something.
1950 Chevrolet 3100 (Ol' Roy)
I
I Offline
Ah, I see.
My chassis, motor and drivetrain are a Chevy P30, so that may be why.
This boot was the one listed for my vehicle on the Mill Supply site. I'll keep the link you send me in mind. Thanks very much.
~~ Konstantine
Follow in the DITY
I
I Offline
Well, the plan yesterday was to install a new GM style headlight switch to replace the off-the-shelf two position headlight switch I have but, as with many well-laid plans, I realized that was missing some components so I had to pick another direction.
What I ended up doing was finally painting the heater box and blower box for the interior of the Grumman. I had purchased some gold metal flake paint quite some time ago, but ended up having to work on more essential things until now. The nice thing about being able to paint means I'm actually closer to done with the essentials and can focus more on the smaller and more fun bits!
The first pick is of the vertical defroster vent which I painted last year in flat black. That's going to stay that color.
The other photos are of the gold metal flake paint I used with a 2K clear I bought from Kustom Canz. I like the quality of the product. It sprayed well, other than every once in awhile the tops were spitting, but it was manageable.
One can of their black base coat was more than enough for the two pieces given that I had also primered them in the same color. One can of gold flake was emptied getting the results you see in the pics on the two pieces. I'm happy with the results and will say the pictures don't do them justice.
Hopefully, next week I'll be able to install them and keep moving forward!
Vertical defroster vent
Heater and blower box prep
Final paint
Final paint
Final paint
Final paint
Final paint
Mad Scientist
Kustom Canz
~~ Konstantine
Follow in the DITY
Looks like they turned out great Kon! thumbs_up
~ Dan
1951 Chevy 3 window 3100
I
I Offline
Thank you! It's slowly coming together.
~~ Konstantine
Follow in the DITY
Page 2 of 2 1 2
Moderated by  J Lucas
