0 members (),
123
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I've been looking for a 60 or 61 hood to put on my 63 suburban for a long time. They're very hard to find in the Midwest partly because they had a rust problem. I finally found a good one on a 60 2ton. Will the hoods switch between the 1/2ton and the 2ton and if they will, what else do I need off the 2ton such as hood latch or hinges to make it work on the suburban? I'm pretty sure the doors and the cab interchange. Can anybody give me the scoop on the hood (no pun intended) Thanks | | | | | Joined: Aug 2003 Posts: 14 Junior Member | | Junior Member Joined: Aug 2003 Posts: 14 | as far a I know the 2ton hood will fit fit the same as the 1/2 ton I used a 1 ton hood on my 1/2 ton and everything lined up alright good luck and keep on truckn | | | | | Joined: Jan 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 59 | It will fit as long as the 2 ton is not a low cab foreward model. I would be sure and get the latch assembly too because there are some differences between year models. Also the lights in the 2 ton hoods were just park lights-the turn signals were mounted on the fenders. However you should be able to use the sockets and wiring from your 63 hood and use amber bulbs if the 60 hood has white lenses. | | |
