0 members (), 72 guests, and 1 robot.
Topics128,196
Posts1,057,394
Members48,471
Page 16 of 16 1 2 … 14 15 16
back yard wrench turner
Originally Posted by TUTS 59
Thor is back at. This thing rides so much better with a load. grin
I'm sure Thor isn't even working up a sweat with that light load. smile
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
My mistake. Factory shop manual says the 216 should have 14 PSI oil pressure at 2,000 RPM.
1950 Chevrolet 3100 (Ol' Roy)
Crusty Old Sarge
Crusty Old Sarge
No Thor just Rattled along, I was the one breaking a sweat... grin
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Finally got around to changing the batteries in the trailcam and found Ol' Roy hauling firewood logs to take to my mom.
Roy seems to handle that steep hill well.
Hahaha! The cam was hung on the tree crooked.
Otto - You get an "A" for catching Ol' Roy at work. grin Not so much for your trail cam hanging - LOL! dang
~ Dan
1951 Chevy 3 window 3100
U
U Offline
Back to the farm for some Halloween pumpkins!
~ John in Utah
Here We Go
Follow in his DITY Bay
U
U Offline
Washer machine stopped working and I had to pick up a new lid switch. I've changed this before years ago, so not that hard to do. I went to The Mending Shed in Orem, UT. The owners were loving the old truck and took some pictures in front of the store.
~ John in Utah
Here We Go
You would think that the owners of The Mending Shed would mend their sign. It's sort of like those mobile auto detailing guys driving around in beat up, filthy wreck vans.
thumbs_up
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
U
U Offline
I thought the same thing when I pulled up. 🤣
~ John in Utah
Here We Go
Ol' Roy is now so quiet that I'm driving it a lot more than usual. The Bismarck and Little Red are getting neglected.
Of course now that it's quiet I keep hearing all kinds of other noises that have probably been there forever but that I just couldn't hear in the past. So now I'm obsessing over them. I probably just need to drive around with ear plugs.
Anyway, I had to go to a Ace Hardware about 6 or 7 miles away because they're the only place left nearby that will still fill propane tanks instead of requiring you to exchange them.
The Blue Rhino, et al tank exchange is a big rip off anywhere you go. Around here the average price for an exchange is about $22, but you only get 15 lb of propane.
At Ace hardware you'll get a full 20 lb for the same $22. That's $1.10 a pound as opposed to a $1.46 per pound. That's over $7 per tank savings.
The good think about the tank exchange places at Kroger or whatever, is that you can take your DOT expired, rusty tanks to them and exchange them for a brand new tank , 3/4 full of propane. If you have to buy a new empty tank, they're almost $50 now! I even found a rusty tank in the woods by my house and exchanged it for a brand new one.
Then off to the bank and some other errands. Gotta get my stuff done before the big hurricane hits tomorrow!
Who knew that having valves open all the way like they're supposed to would have such a positive effect on the performance of this vehicle?
Hahaha!
The truck has noticeably better acceleration. It was no slouch before but it's measurable now. And I did not even push the truck to get to those speeds. Whereas prior to the valve adjustment and repair of the rocker arms and shaft, it would make it to 55 and 60 comfortably and it was a stretch to make it to 65.
So obviously my first sentence was tongue in cheek but I'm amazed by this old truck. I also noticed that the RPM increased without me messing with the carburetor.
I assume because it's running so much more efficiently. I do believe it was running rich in the past due to soot in the tailpipe and on the garage floor.
I actually expect to see a measurable improvement in fuel economy. It was getting about 11 to 13 prior to all of this work.
I turned the idle back down to 600 it had climbed to 800 on its own.
And let not your hearts be troubled. I'm not driving around regularly at 70 miles an hour on the interstate. I just took it out after turning the idle down to see how it was running.
Definitely driving it to work tomorrow, though.
Otto, is the slightly to the discharge side of "0" normal for your truck? I know that ammeters can be off a bit but I am always concerned if they show a discharge while operating.
1949/50 3600 Project
Follow in Project Journals
I'm driving the truck this morning. I'll look more closely when I leave from where I'm at. It might just be the angle at which the photograph is taken.
Can that actually be called a photograph? What are digital images taken on a phone called?
I'll hook them multimeter up when I get home and see what the output is with the engine running.
24601
24601
You got it, Otto. They are correctly referred to as "images" because "photograph" is a specific term referring to an image captured and reproduced through the "photographic process" involving an optical lens and a light-sensitive chemical process. "Images" are a more generic form of graphical representation encompassing a variety of forms and formats.
While the camera doesn't lie, Photoshop sure does! Once an image is transferred from the film to an electronic format, it ceases to be a "photograph" and has become merely a manipulated image who's veracity is suspect.
Old School Newspaper Editor/Journalism Instructor
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
And to allay WIcruiser's concerns, I just drove to my next stop and the needle stayed more less in the center of the ammeter gauge. It jiggles around a little bit. But I turned on the heater and it didn't go to discharge. I'll try the headlights and the heater next and see what happens.
You said it john. As useful and amazing as this modern technology is, I definitely prefer old technology. I still have 35 mm film cameras that I use semi regularly. But it sure is nice being able to take 100 pictures with a phone and then keep only the one you want
I used to have a photographic memory...but I ran out of film.
Chris
G.O.T. (Good Ol' Truck), 1953 Chevy 3609 AD 3/4 ton with original 216 c.i. engine, 4 speed transmission, stake bed
7.34 on the volt meter
AD Addict & Tinkerer
When the battery reaches its full charge, the current flowing into it drops to essentially zero. The ammeter therefore reads zero amps even though the generator is still producing electricity offsetting any draws on the battery, lights, coil, etc.
In short, a zero reading tells you the battery is fully charged and that the generator is successfully meeting the truck’s electrical demand.
When you first engage the starter, the battery supplies a noticeable surge of current to the engine. During this brief period you should see the ammeter swing negative, then upon starting, it should swing to the positive side indicating that the generator is beginning to replenish the charge the starter just drew.
A more reliable way of testing your charging system when it’s running, is to use a multimeter on volts. It should show about 6.5-7.5 volts on a six volt system (13-14.5 volts on 12 volt system) if it’s charging properly.
Last edited by Phak1; 10/13/2026 5:27 PM. Reason: Made a correction and added info
Phil
Project Journals
U
U Offline
My truck has been driving good. I did test the alternator/battery to see that it is receiving a charge, around 14.3v. I struggled with my wiring project, so I don't know that I have everything wired correctly. My ammeter stays in the center when I turn on my headlights or step on the brakes. But when I use my turn signals, the needle does go to the discharge side and then back to zero for each blink. That's one way I know the turn signals are working because the little green light at the end of the turn signal handle doesn't work all the time.
~ John in Utah
Here We Go
I don't have a 1946 Chevy truck wiring diagram, but both 1945 and 1950 diagrams have only the starter motor and the horn not going through the ammeter. Properly wired, any other electrical load should cause the ammeter to show additional discharge. Might be hard to see if the engine is running.
Glad to hear your charging system is working as intended. One of the reasons I like a volt meter over an ammeter is the scale is easier to identify small changes in performance because a 1 or 2 amp discharge on a 20+ amp scale is pretty small whereas 12 volts rather than 13 is pretty easy to see.
I never expected my question to result in such a diverse discussion but I guess it just goes to show how many people are paying attention on this forum.
This is a 6v system. As long as the needle is more or less in the center, I'm fine with it. The heater is the only electrical option on the truck. I see the needle jump to D when I turn on the headlights but then centers itself quickly.
This farm wagon has been stored at my brother's for the last several years. This summer he asked me to come and get it, as he no longer had room for it.
I don't have room either, but I don't want it to set outside over winter. Since my trucks will be going into winter storage in the next couple weeks, I came up with plan B. Problem solved!
Rich
1947 Loadmaster
U
U Offline
That's hardly taking up any space at all! 😁
~ John in Utah
Here We Go
How do you get it on and off?
Rich - Plan B is a perfect solution! grin Kudos and thanks for saving the farm wagon and sharing the picture of your truck being used as a truck! thumbs_up
~ Dan
The road ditch in front of our house is very steep, almost vertical in a couple places. We backed the truck in there and the back of the bed was very near the road. We laid a couple short plank down, then brought the wagon out on the road, then my brother and I pushed it by hand onto the truck.
Rich
1947 Loadmaster
Crusty Old Sarge
Crusty Old Sarge
Ain't Flatbeds COOL... grin
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
U
U Offline
Light duty at the neighborhood Trunk 'n Treat at the church parking lot. Good weather and a big hit with Oreos, Reese's and Nutter Butter Pieces. All the dads were checking out the truck for the first time. Not really work, but... 🙂
~ John in Utah
Here We Go
Crusty Old Sarge
Crusty Old Sarge
Well sort of used Thor today...it makes a great work platform. grin
Thor...work platform
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
V
VEW Offline
V Offline
Thor has always been universally available. Was used as a stage for a couple of bluegrass concerts too.
~ Victor
1957 3100 - moved on
Crusty Old Sarge
Crusty Old Sarge
Now that's COOL 😎..
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
U
U Offline
Well I guess that's thinking outside the box! Thor giving support where it's needed.
~ John in Utah
Here We Go
24601
24601
Victor,
Use as a stage for concerts is a good use for a Stovebolt. Here's mine
'72 GMC 9500 as a stage at Kansas City
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
John, What the heck is that gizmo on the right of your photo? A camera stand?
