2 members (latroca52, crenwelge), 149 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,469
#1613770 10/22/2026 12:27 PM
I have scrapped the 235 engine I previously listed but retained the following items for potential sale if anyone is interested. In keeping with forum rules I have listed prices for the items but I have not researched pricing and am therefore willing to consider any offers. I do have some pictures and can get specific pictures of anything that is required to help move these parts out of my storage area (I don't have a need for any of them). All prices are cash or paypal and do not include shipping.
Cylinder head - 848 with rocker shaft and rockers. $100
Starter - engine was in theory converted to 12v but I did not clean off the tag to confirm if the starter was changed (level of crud etc. would indicate it was not). $25
Intake and exhaust manifold - heat riser is free to move - $35
Carburetor - Rochester - $25
Distributor - complete with advance mechanism - $35
Bell Housing - previous had 4 - speed transmission attached - $25
Flywheel - I did not check the number of teeth on the ring gear, brief inspection did not show cracks or heat checking, clutch surface seems okay. $35
Clutch - lining material looks okay but probably would need to be relined. $25
1949/50 3600 Project
Follow in Project Journals
Is the engine block beyond help for some reason?
Engine block (with all it's internal components) was scrapped earlier this week.
"Another one bites the dust!" Too bad I'm not closer to you, I would have been glad to have it!
PM sent
This is the manifold as it sits. The oil filter assembly could be removed if not desired. There is a casting number on the intake portion that I believe is 3B35590.
The intake manifold is more likely "3835590" which is listed in my resource references as used on 1948-56 235's.
The exhaust manifold casting number "3835587" is also confirmed as being listed for 1948-56 235's.
Looks like a matched set ready to find a new home.
Best if luck! thumbs_up
~ Dan
1951 Chevy 3 window 3100
