1 members (1 invisible),
116
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 268 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 268 | I’ve found that many well versed engine techs recommend to store crankshafts vertically . Why? My opinion is that it’s probably reasonable to think that if it’s tipped the shaft may crack or severely be damaged. Ok I see no issue with storing it horizontally if the shaft is supported at the 4 primary journals. So? | | | | | Joined: Feb 2000 Posts: 5,239 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,239 | Mostly its space need to store it laying down. If laying one down can bend it, how would it ever hold up in an engine? I tried to break a camshaft once, took it out in the street and me my buddy kept throwing as high as we could, it might have bent it slightly, but it wouldn't break, we had to set it on a couple 2x4's and hit it with a sled hammer to break it in half. I am willing to bet a crankshaft would take a fair amount of work to bend or break one. | | | | | Joined: Mar 2021 Posts: 268 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 268 | Thanks. I was pretty sure that responses would basically say what you’ve pointed out. It makes a lot of sense to me. Shortly I’ll be removing the crankshaft and I’ll store it horizontally, I just feel better storing it like this. | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | When I ran the connecting rod reconditioning department at a big machine shop in Nashville, we stored crankshafts in a steel rack, hanging by the flywheel flange, but it was mostly for space saving- - - - -50 or more crankshafts in stock at a time, including Cummins Diesel shafts about 5 feet long. I think the old myth about a shaft bending if stored flat is a bunch of hogwash! Jerry
| | | | | Joined: Mar 2021 Posts: 268 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 268 | Jerry I was pretty sure that those crankshafts must be able to withstand properly horizontally stored because they are quite sturdy. Now if someone was to drop it from a 20 foot high that’s another conversation. Thanks | | | | | Joined: Oct 2021 Posts: 6,961 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,961 | You can find lots of pictures on the internet of crated crankshafts stored horizontally. They usually are resting on saddles positioned at some or all of their journals. No way the military would store thousands of spare crankshafts vertically.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,168 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,168 | Other than hanging cranks from the flywheel flange like Jerry mentioned, vertically crated crankshafts would be unstable (more easily knocked over) versus a horizontal crate. NOBODY would store or transport them in a vertical crate. I doubt that even a 20 ft drop would do more than some cosmetic damage to a 235 crankshaft.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2021 Posts: 268 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 268 | | | |
