5 members (Wally / Montana, Otto Skorzeny, 2-Ton, ShopRag, klhansen), 80 guests, and 4 robots.
Topics128,263
Posts1,058,133
Members48,482
#1613446 10/16/2026 10:21 PM
My 66 C10 has the Economy (cheaper) heater - defroster assembly. I was able to get the top off of the under hood assembly and remove the heater core. How do I remove the blower? Do I have to remove the assembly under the dash? Thanks for any advice.
Professional Novice
Frank50 #1613575 10/19/2026 1:57 AM
Socket Breaker
Socket Breaker
The blower has a few screws attaching it underneath. Then it drops down from the heater core box, if it is original.
On my truck with a later V8, I have to loosen the box the heater core is in for more wiggle room.
Here are some photos:
04/19/2017 – heater core replacement
Check the captions on the photos.
Also, look for a link to an earlier replacement for more pictures.
Look for a link to Burgies page about this too.
Good luck.
Frank50 #1613723 10/21/2026 4:49 PM
Thank you! Very detailed.
Professional Novice
Frank50 #1613745 10/21/2026 10:13 PM
Socket Breaker
Socket Breaker
You are welcome, I hope it helps.
-Woog
