Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, greenie-reddy, dt235sd, frogfarmer), 101 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
The 2004 rear end came from a salvage yard truck that had been there for a few years. Before I put it on the road I would like to replace the gear oil. I find no plug by which to drain it, and the owners manual in my 2007 truck just says if it leaks, repair it. How can I drain it without removing the cover?
You cannot..........
Ron - - Dusty53
1954 Chevy 3604
O Online: Content
Loosen the bottom few bolts and let it drain.
Or, can you suck it out of the filler hole?
1950 Chevrolet 3100 (Ol' Roy)
Crusty Old Sarge
Crusty Old Sarge
You could always add a drain plug in the cover after you remove it.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
