2 members (78buckshot, cmayna),
111
Mod | | | Forums66 Topics128,279 Posts1,058,593 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2025 Posts: 75 'Bolter | | 'Bolter Joined: Nov 2025 Posts: 75 | The 2004 rear end came from a salvage yard truck that had been there for a few years. Before I put it on the road I would like to replace the gear oil. I find no plug by which to drain it, and the owners manual in my 2007 truck just says if it leaks, repair it. How can I drain it without removing the cover? | | | | | Joined: Jul 2014 Posts: 1,294 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,294 |
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Oct 2021 Posts: 7,049 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,049 | Loosen the bottom few bolts and let it drain.
Or, can you suck it out of the filler hole?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2007 Posts: 3,503 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,503 | You could always add a drain plug in the cover after you remove it.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
