3 members (DadsFirstPickup, 55shaker, 1 invisible), 300 guests, and 2 robots.
Topics128,152
Posts1,057,011
Members48,460
#1613114 10/12/2026 3:52 PM
1954 261 truck.
Had the Flywheel resurfaced. Reusing the same Release Bearing, PP and Disc. Adjustment makes no difference except the pedal feel. There is movement but very little. No visible gap between the disc, PP or Flywheel. Clutch will not release. Help?
How much thickness was removed from the flywheel surface? You might need to fabricate a thin shim between the crankshaft flange and the flywheel to compensate. Try putting flat washers between the pressure plate and the flywheel temporarily to space the pressure plate back a little, and see if that helps the problem.
If the flywheel was machined flat (which it should be), maybe it was worn enough prior to disassembly to provide release clearance for the disc, but the linkage adjustment should take care of it. Are you 100% sure that the release arm is in the right position? Mounting the flywheel farther back (shim between crank flange and flywheel) likely won't help at all, but spacing the pressure plate back with washers should compensate, but will reduce clamping pressure on the disc.
Insomniac
Insomniac
Throw out bearing installed backwards?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
NO, I don't think it will go backwards. Fork slot is to the rear?
Thanks Jerry!
I will try the washers. Machine shop didn't say how much was removed just that it cleared up. I didn't think to ask. Is there any such think as a shim for the Flywheel?
Thank you KLhansen for the reply.
I think the arm will only go one way, you agree? IS there a dimension on how far the three pieces, FW, PP and Disc, should separate when depressing the clutch. I have very little movement.
RLB Offline
Clutch dsc is in backwards.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
I thought so myself but I have now tried it both ways. Thanks
RLB #1613158 10/12/2026 10:05 PM
Originally Posted by RLB
Clutch disc is in backwards.
That's a distinct possibility. The torsion springs in the clutch hub should face toward the transmission, protruding back into the center of the pressure plate. If the springs are toward the engine, they will drag on the flywheel attaching bolts and prevent the clutch from releasing.
Can either of you give me some idea of how thick the washers/spacers between the flywheel and PP shouldbe not knowing as said before how much was removed from the PP during resurfacing?
You didn't have the pressure plate resurfaced, did you? That would actually cause the reverse of what you're saying is happening that the clutch doesn't release. Resurfacing the pressure plate would reduce the pressure on the disk by a bit, the same thing as stacking washers under the pressure plate mount bolts. It would actually cause it to release sooner, everything else being the same. I think you need to go thru the linkage to be sure it's correctly installed and adjusted. How much pedal movement do you have before it starts getting firm? It should only be about an inch. It could be less than that as long as there's no pressure against the throwout bearing with the pedal released.
A 1/16" flat washer thickness would correspond to about .060" being surfaced off the flywheel face. That would be a HUGE amount for a machine shop to take off- - - - -half of that or less would be much more likely.
Many Thanks!!
The washer thing is not a good idea, IMO. Putting washers in is essentially the same as using a thinner clutch disc, reducing the pressure on the disk. Surfacing a flywheel does nothing to change the relationship of the pressure plate and the disc, other than moving the entire assembly forward. Like Jerry said 0.060" taken off the flywheel would be way more than needed, and even if they did take that much off, all it would do is add 1/16" to the distance the throwout bearing would have to move before it contacted the fingers on the pressure plate. That amount should be easily taken up by linkage adjustment.
As I've said before, RECHECK THE LINKAGE ADJUSTMENT.
1 Offline
Did the clutch work properly before the resurfacing?
I would suspect the pressure plate.
Thank you Klhansen.
I went so far with the linkage as to shorten the link rod by 3/4". Didn't change a thing. I've had the adjustment as far as it will go in both directions, nothing changed. Regardless of where the adjustment is set, the movement I am seeing seems to remain constant. What actually happens to a PP when it fails or gets week? All the springs look to be intact.
55 1st Series.
Yes it was fine, no slippage at all. Does anyone know how much movement one should see when the pedal is depressed, I am seeing MAYBE an 1/8", no more than that?
your pressure plate/disc is not installed backwards?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
they are correct. Fat side of the clutch disc is to the transmission. No contact with Flywheel. For some reason I am not getting the needed movement when depressing the clutch. There is movement but it is SMALL. Doesn't release the disc.
Have you tried reinstalling the old clutch disc? The new one might have lining material that's too thick.
1 Offline
I think I would extend the adjustable arm as long as possible removing all free pedal just to see if the pressure plate will release pressure on the clutch disc. If it doesn't release, then the problem would point to the pressure plate in my opinion.
There are two, or possibly even three different lengths of throwout bearing carriers- - - -the round piece that slides on the front bearing retainer of the transmission. The design of the pressure plate spring fingers determines which one is correct. A short bearing carrier where a long one is supposed to be used can cause the problem you're having.
If you’re using the same setup as before, pressure plate, disc and throw out bearing, and the only thing you did is resurface the flywheel, and everything went back together correctly, then it should work with the same linkage setting as before.
Unless, when you removed the transmission you let it land hang on the disc, which might have bent the hub of the disc and caused it to hang up either on the splines or remaining in contact with the flywheel on one side and the pressure plate on the other.
When you say it won’t release, is that with the engine running? Try starting the engine with the transmission in gear and the clutch pedal depressed. If the truck doesn’t move then the clutch is releasing.
Everything you stated is correct. All parts were as they were prior to the resurfacing. The transmission was not left hanging on the front shaft as I was using a floor jack and fixture. The disc slides easily on the transmission shaft when the transmission is removed. I tried a second disc and the truck acted the same way. By "won't release" I mean with everything installed and the engine running, trying to go to low or reverse results in a grinding of gears. Shutting it down and shifting into low or reverse then touching the starter and the truck tries to move with the clutch depressed. Only if I shift to neutral will it run and not try to move. It has a B&B PP made in Korea. When PP fails, what happens? This release issue or slippage? Could the movement diminish? I can't find any info on how much actual movement it takes to cause the clutch to release, I have some movement but it is small and you cannot move the disc between the two plates with the clutch pedal blocked down. I could try a new PP but I will have to have another B&B I think due to the stack up height being much less with the diaphragm type PP. It also has a tall style release bearing. Any idea where I might find a B&B PP? 10" Clutch. Thank you!!
TO bearing is the same one that came out. All parts are being reused. Only change is the resurfacing of the FW and the wear indicator ring is still there and it is about .015 deep. Thanks.
If your clutch worked previously and you installed the same parts, it should work. That points me to adjustment or installation of the linkage. I've got nothing else to offer. Sorry.
I don't know the amount of travel required to release but it is not a small amount when measured at the outer end of the clutch arm. If you only have a small amount of travel something has changed in the stack up of parts between the clutch pedal and the clutch arm. The good news is that is all external to the bell housing so you shouldn't need to dig too deep to find the solution.
1949/50 3600 Project
Follow in Project Journals
