Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Jon G, 78buckshot), 87 guests, and 1 robot.
Topics128,279
Posts1,058,593
Members48,492
#1613430 10/16/2026 5:30 PM
B Online: Content
The Carter YF 964S (was on my '52 GMC when I bought it 13+) years ago started having problems about 6 months ago. When it sat over night the float bowl would drain down, which meant I had to crank the engine over a bunch before it would start. Also, the mileage dropped from about 13 MPG to around 6.
I removed the Carter and installed a Zenith 28 (which was the proper type for my 228, but not the exact model) that I had. It ran okay, but not near as good as the Carter.
I bought a kit for the YF and installed it last week. Truck seems to be running fine, although idling a bit high. I filled the gas tank this morning and will report MPG results after the next fill up.
BUT ....
Two of the 10-28 edit:actually 10:32 screws (see picture) that hold the top feel like they want to strip out the threads in the body of the carb. They are still holding somewhat and the carb doesn't appear to be leaking. The only "fix" I can think of would be to drill and tap the two blind holes in the body to #12 size machine screws.
QUESTIONS:
Anyone have a better idea?
If #12 screws are the answer, should I use 12-24 or 12-28.
Crusty Old Sarge
Crusty Old Sarge
Maybe just a drop of green Locktite on the threads. It's not the correct fix but if it's not leaking at the moment. I would do each screw one at a time, so as not to lose the gasket seal.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I'm pretty sure I have some 10-32 helicoils in my box of stuff, which is what I'd use. 10-28 is an uncommon thread pitch, so I'd confirm what you have first. If you do drill for #12 screws, match the pitch to what the #10's are (10-32 fine or 10-24 coarse).
The #12 screw heads would look weird, being bigger.
Bill Hanlon #1613445 10/16/2026 10:02 PM
B Online: Content
I don't know "green" loctite Craig, but I'll look it up.
Kevin, I had 28 tpi on the brain while thinking about the #12 screws. The current screws are 10-32 (I think). I didn't realize they made helicoils that small. How big do you have to drill the hole in the carb for the helicoil? There isn't a lot of meat available.
Bill Hanlon #1613450 10/16/2026 11:30 PM
Get some longer screws and see if they run all the way through into some remaining good threads. If you feel any resistance, stop and remove the long screw and run a tap all the way through.
This has worked for me in the past.
Basically to install a helicoil, the drill size is the same as the major diameter of the size you're installing. So you're not really taking out that much metal. I have just run the helicoil tap through a part with fully stripped threads without drilling. The set I have is 10-24 and needs a 13/64 drill. Drill size for a 10-32 helicoil would be the same. It looks like you can get a 10-32 helicoil type thread repair kit for under $30 on Amazon. Actual Helicoil brand is crazy expensive now.
Carburetion specialist
C Online: Content
As Kevin mentioned, genuine Heli-Coil kits ARE expensive, but if you shop ebay, you can generally find them fairly close to the price Kevin quoted for the Amazon kit.
There used to be a cliche: "You get what you pay for".
Sometime ago, I paraphrased that cliche as follows: "You generally DON'T get what you don't pay for".
Over the last 50 years, I have installed hundreds of genuine Heli-Coils, with NEVER an issue.
I did test some of the less expensive knock-offs and then threw away the castings.
You get ONE opportunity to correctly fix the stripped threads, and then you get to replace the carburetor.
Which is the most expensive; the Heli-Coil kit or a carburetor ?
Jon
The Carburetor Shop
C Online: Content
One other suggestion:
Which ever way you go, DON'T try to use a hand drill. Make a suitable fixture to attach the carburetor to the base table of your drill press, and CENTER the bit for drilling.
Once you have the hole drilled, UNPLUG the drill press, and use the drill press head to hold the tap, and rotate the drill press head by hand.
Even a genuine Heli-Coil would have issues if not installed "plumb".
Do it right, the first (and only) time.
Jon
The Carburetor Shop
B Online: Content
Great suggestions Jon.
I have a drill press and a question. How much force on the downfeed handle?
For now (and until I detect a leak or have to tear down the carb for some other reason) I'm just going to let well enough alone. I will get a genuine Heli-Coil set and hopefully that will keep me from ever needing it.
C Online: Content
Bill - just enough to get the tap started a couple of threads, and then it will take care of itself.
In the "for what its worth" category, the really "tricky" ones are the throttle plate screws. When still doing carburetors, we used to have a lot of units sent to us with a twisted throttle plate screw. We actually received a four-barrel once with ALL eight throttle shaft screws twisted.
Heli-Coil makes the inserts in different lengths; when doing the throttle shaft repairs, use the "short" inserts, or better yet, don't twist off the screws.
Jon
The Carburetor Shop
B Online: Content
I removed one of the screws and checked thread pitch. It is definitely 10-32.
Jon: I'm looking at a HeliCoil 5528-3 kit. But the specs show that the lengh of the insert in the kit is 0.285". That should be about 9 turns of thread on the screw. The blind hole into the carb body is more than twice that deep. Do I need a different set of inserts? If not, do I install the inserts at the beginning of the hole or down at the end?
HeliCoil lists these inserts in 10-32:
• 1D (Short): ~0.190 inches overall length (OAL)
• 1.5D (Medium): ~0.285 inches overall length (OAL)
• 2D (Long): ~0.380 inches overall length (OAL)
• 2.5D: ~0.475 inches overall length (OAL)
• 3D: ~0.570 inches overall length (OAL)
O Online: Content
What happened to Carl's suggestion about tapping the hole for longer screws? Seems a lot easier and less risky that a Helicoil fix.
I also did this on a carburetor for another vehicle.
1950 Chevrolet 3100 (Ol' Roy)
Bill, Usually the inserts that come with the kit are long enough for most uses. You can also stack inserts in the hole if you need more threads (drive the first one to the bottom and then thread another insert in on top of it.) But for your application, I'd say that 9 threads would be fine (installed at the top of the hole.)
I hear what Jon says about the knock-offs, but I have used them successfully. I do have genuine Helicoils in various sizes though, and prefer them if readily available. I've even used Helicoils on stripped weld nuts (the one on the stake pocket for the tailgate hinges.)
In my opinion there is no risk trying what I recommended. If it doesn't work, one can just go with a helicoil fix.
Bill Hanlon #1613570 10/19/2026 12:52 AM
C Online: Content
I would also vote for at least attempting to use longer screws.
Just do not fall prey to the stainless steel ads, go for zinc plated steel just like the original.
Jon
The Carburetor Shop
Try tapping the carburetor housing for a 5MM X 0.8MM thread. That's about .009" larger than a 10-32, and it should allow you to get a full thread in the housing without having to use Helicoils.
toolsadvisers.com/what-size-drill-for-m5x0-8-tap
B Online: Content
I have a HeliCoil kit for 10-32 on the way.
For now, I'm just going to watch for a leak. I've been driving it for about a week with no leakage noticed.
Yesterday we had a "clean up day" in our little 24 lot country subdivision. I was on a crew that trimmed trees along side the only road and my truck was used to haul the trimmings to a burn pile. The driving included some fairly steep offroad downhill, uphill, lean to the left and lean to the right through ditches. I left the engine running and saw no evidence of leakage.
If I notice a leak the first step will be to remove the screws, measure the depth of the hole and see if there is any room to run longer screws. Also may run a bottoming tap into the hole if it feels like there is room for improving the depth, then get longer screws if they will tighten without bottoming. If that fails, I'll run the HeliCoils.
Jerry: I'm afraid my YF would refuse to work with metric screws installed. wink
Bill Hanlon #1614965 11/07/2026 11:11 PM
B Online: Content
This entry should finally close out this thread.
Finished my first full tank of gas today with an average of 13.55 MPG. grin That is about the same as this Carter YF 964S was getting the last time I rebuilt it 40,000 miles and about 12 years ago. It had recently dropped to around 6-7 MPG and would drain down overnight causing 5-6 seconds of cranking my 6 volt starter with a 12 volt battery before the first start of the day.
The two suspect 10-32 screws seem to be doing okay, with no apparent leaks down the side of the carb's body. If I notice leaking I have a 10-32 HeliCoil kit at the ready.
The only problem I still have is that the throttle doesn't want to completely close when I let off the gas pedal. It hangs at about 600 RPM (which is fine for A/C season) instead of dropping to the 425 RPM specified in the Maintenance Manual. If I just tap the gas pedal the engine drops to 425 RPM. I've removed the throttle linkage from the carb and tested. With the linkage unhooked the RPM drops like it should, so the carb isn't the problem, it's the linkage. Maybe a little squirt of lube.
My thanks to all of you who contributed to this thread. shake
Bill Hanlon #1614968 11/07/2026 11:32 PM
O Online: Content
Do you have a manual throttle cable? If so, check that. My truck did exactly the same thing. The linkage would get stuck on the throttle cable when the pedal is released. Tapping it lightly got it unstuck and the rpm dropped to normal.
Bill Hanlon #1614970 11/08/2026 12:48 AM
B Online: Content
It did originally, but I removed it years ago. Used the hole in the dash for a high beam indicator, which wasn't included in the aftermarket gauge set that came to me in the truck.
A week return spring will prevent the throttle from closing.
I you hook your toe under the gas pedal and pull up on it and the throttle closes, it's your return spring.
