5 members (MickeyP, papas52, dt235sd, GA Boy, dgrinnan), 76 guests, and 1 robot.
Topics128,169
Posts1,057,035
Members48,458
#1613335 10/15/2026 6:21 PM
back yard wrench turner
since I drove my truck.
I went out yesterday to make sure it would start and run for a Little Blue Truck Day.
The clutch had stuck to the flywheel and I couldn't shift into gear from neutral.
I started it with the transmission in 1st gear. I held in the clutch pedal, it moved forward, and gave I it a good boost with the gas pedal.
The clutch released and now all is good. Until next time. This has happened several times over the last 15 years.
I need to remember to drive it more often.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
That's something you need to remember?
Every time I see any of my vehicles, I make excuses to run errands just so I can drive them.
Wayne, put your truck into regular rotation with your other cars and when it's the truck's turn, regardless of the "mission", drive it! Don't make excuses not to drive it like it doesn't have ac or power steering, or gas is too expensive or some other bogus reason.
Vehicles don't like sitting around doing nothing. That's when they start falling apart, as you've experienced.
1950 Chevrolet 3100 (Ol' Roy)
That's less likely to happen if you wedge a piece of 2 X 4 between the seat and the clutch pedal when the truck will be parked for a while- - - - -holding the pedal down. Use the parking brake or chock a wheel front and rear.
Moderator
Moderator
2 Offline
I have been using Jerry’s idea on the 46 I have now. Big rear main seal leaking bad. If I leave it sit just for a couple days, it sticks,
I put it in second or third gear with the clutch depressed and bump the starter without the key on. It will break loose and them turn on the key and start it. I use a one by two and keep it in the cab all the time.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Crusty Old Sarge
Crusty Old Sarge
In Wayne's defense he and his Bride just returned from a lengthy trip.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
And my wife asks me "Why do you drive your truck so much?" thumbs_up
Craig
My '47 has done that a few times. As mentioned, I start it in gear with the clutch pedal depressed and the other foot on the brake. That's always worked so far. I also block the pedal down with a 2 x 4 when it's going to be sitting for a while.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
