8 members (lumbersawyer, MickeyP, Gdads51, Shade Baby, Charles in CA, Rusted Nut, Woodcmiami, CATMAN),
163
Mod | | | Forums66 Topics128,162 Posts1,056,947 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | 1954 261 truck.
Had the Flywheel resurfaced. Reusing the same Release Bearing, PP and Disc. Adjustment makes no difference except the pedal feel. There is movement but very little. No visible gap between the disc, PP or Flywheel. Clutch will not release. Help? | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | How much thickness was removed from the flywheel surface? You might need to fabricate a thin shim between the crankshaft flange and the flywheel to compensate. Try putting flat washers between the pressure plate and the flywheel temporarily to space the pressure plate back a little, and see if that helps the problem. Jerry
| | | | | Joined: May 2015 Posts: 11,138 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,138 | If the flywheel was machined flat (which it should be), maybe it was worn enough prior to disassembly to provide release clearance for the disc, but the linkage adjustment should take care of it. Are you 100% sure that the release arm is in the right position? Mounting the flywheel farther back (shim between crank flange and flywheel) likely won't help at all, but spacing the pressure plate back with washers should compensate, but will reduce clamping pressure on the disc.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,200 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,200 | Throw out bearing installed backwards?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | NO, I don't think it will go backwards. Fork slot is to the rear? | | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | Thanks Jerry!
I will try the washers. Machine shop didn't say how much was removed just that it cleared up. I didn't think to ask. Is there any such think as a shim for the Flywheel? | | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | Thank you KLhansen for the reply.
I think the arm will only go one way, you agree? IS there a dimension on how far the three pieces, FW, PP and Disc, should separate when depressing the clutch. I have very little movement. | | | | | Joined: Feb 2023 Posts: 385 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 385 | Clutch dsc is in backwards. | | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | I thought so myself but I have now tried it both ways. Thanks | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Clutch disc is in backwards. That's a distinct possibility. The torsion springs in the clutch hub should face toward the transmission, protruding back into the center of the pressure plate. If the springs are toward the engine, they will drag on the flywheel attaching bolts and prevent the clutch from releasing. Jerry
| | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | Can either of you give me some idea of how thick the washers/spacers between the flywheel and PP shouldbe not knowing as said before how much was removed from the PP during resurfacing? | | | | | Joined: May 2015 Posts: 11,138 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,138 | You didn't have the pressure plate resurfaced, did you? That would actually cause the reverse of what you're saying is happening that the clutch doesn't release. Resurfacing the pressure plate would reduce the pressure on the disk by a bit, the same thing as stacking washers under the pressure plate mount bolts. It would actually cause it to release sooner, everything else being the same. I think you need to go thru the linkage to be sure it's correctly installed and adjusted. How much pedal movement do you have before it starts getting firm? It should only be about an inch. It could be less than that as long as there's no pressure against the throwout bearing with the pedal released.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | A 1/16" flat washer thickness would correspond to about .060" being surfaced off the flywheel face. That would be a HUGE amount for a machine shop to take off- - - - -half of that or less would be much more likely. Jerry
| | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | | | | | | Joined: May 2015 Posts: 11,138 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,138 | The washer thing is not a good idea, IMO. Putting washers in is essentially the same as using a thinner clutch disc, reducing the pressure on the disk. Surfacing a flywheel does nothing to change the relationship of the pressure plate and the disc, other than moving the entire assembly forward. Like Jerry said 0.060" taken off the flywheel would be way more than needed, and even if they did take that much off, all it would do is add 1/16" to the distance the throwout bearing would have to move before it contacted the fingers on the pressure plate. That amount should be easily taken up by linkage adjustment. As I've said before, RECHECK THE LINKAGE ADJUSTMENT.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2019 Posts: 397 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 397 | Did the clutch work properly before the resurfacing? I would suspect the pressure plate.
| | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | Thank you Klhansen.
I went so far with the linkage as to shorten the link rod by 3/4". Didn't change a thing. I've had the adjustment as far as it will go in both directions, nothing changed. Regardless of where the adjustment is set, the movement I am seeing seems to remain constant. What actually happens to a PP when it fails or gets week? All the springs look to be intact. | | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | 55 1st Series.
Yes it was fine, no slippage at all. Does anyone know how much movement one should see when the pedal is depressed, I am seeing MAYBE an 1/8", no more than that? | | | | | Joined: Dec 2020 Posts: 1,970 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,970 | your pressure plate/disc is not installed backwards?
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Dec 2024 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 20 | they are correct. Fat side of the clutch disc is to the transmission. No contact with Flywheel. For some reason I am not getting the needed movement when depressing the clutch. There is movement but it is SMALL. Doesn't release the disc. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Have you tried reinstalling the old clutch disc? The new one might have lining material that's too thick. Jerry
| | | | | Joined: Oct 2019 Posts: 397 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 397 | I think I would extend the adjustable arm as long as possible removing all free pedal just to see if the pressure plate will release pressure on the clutch disc. If it doesn't release, then the problem would point to the pressure plate in my opinion. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | There are two, or possibly even three different lengths of throwout bearing carriers- - - -the round piece that slides on the front bearing retainer of the transmission. The design of the pressure plate spring fingers determines which one is correct. A short bearing carrier where a long one is supposed to be used can cause the problem you're having. Jerry
| | | | | Joined: May 2015 Posts: 11,138 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,138 | If you’re using the same setup as before, pressure plate, disc and throw out bearing, and the only thing you did is resurface the flywheel, and everything went back together correctly, then it should work with the same linkage setting as before. Unless, when you removed the transmission you let it hand on the disc, which might have bent the hub of the disc and caused it to hang up either on the splines or remaining in contact with the flywheel on one side and the pressure plate on the other. When you say it won’t release, is that with the engine running? Try starting the engine with the transmission in gear and the clutch pedal depressed. If the truck doesn’t move then the clutch is releasing.
