3 members (Tiny, 1955 1 Series, Hotrod Lincoln), 137 guests, and 2 robots.
Topics128,162
Posts1,056,935
Members48,458
Page 2 of 2 1 2
Alright - we carry on. First snow for the season and I have my GMC 48 in my heated shop. He was in my machine shop since last year, dry and well protected.
The tasks at hand: Remove driveshaft, engine & transmission, then front & fenders and cab.
Please have a look at the firewall, I assume the 'red' is the original color. Go back to it or use something close to the green the main color is now? Any thoughts?
One more question: windshield & rear window glass seems to be good and usable. Just cut the rubber gaskets and pull them out?
Cab etc.
~ NORTH OF 49TH
1948 GMC Model 9434 Frame rebuild
1953 Chevrolet 1314 1/2 ton rebuild
Follow along it the DITY Bay
Yes, you can slice the gasket around the windshield and rear window to get the glass out. That's the easiest way.
On the color, GMC different color choices than Chevy trucks. My first thought was your red was Chevy Omaha Orange, but it's definitely a red. The red on the cab where the bed was is a sign of the original color. This LINK should show the colors available for 1948, although it's for 1950. The same red was available in 1946. A modern paint code for Pimpernel Scarlet is Martin Senour NAPA 98L-1014.
As mentioned, it appears that Red was the original color. But it's your truck. Paint it whatever color you want.
Are the rubber gaskets in bad shape? Otherwise, just curious why you're removing them if the glass is in good shape.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Hello Rich,
certainly, I can pick the color I want and I prefer green. Gaskets, the cab needs to be cleaned, rust removed, probably with a low abrasive blasting and re-painted. All this is much easier with everything removed. Old gaskets are stiff, don't seal well and are a pain to remove and re-install. Just cutting them out is the simplest but no change possible once this is done. thinking
BTW, I noticed the driver side windshield has a rock-chip.
~ NORTH OF 49TH
As I mentioned, GMC colors are different than Chevy. While Chevy used only Forester Green as a standard color [on edit] forgot Chevy's optional Seacrest Green [/edit], GMC had 4 different greens in 1948.
If you want to go with one of the original GMC colors, here are the codes. But like Rich said, it's your truck. Pick whatever color you like.
Apple Green - Martin Senour #115 (striping color on earlier Chevys)
Brewster Green - Martin Senour #111 (Chevy stopped using that before 1948)
Morat Green - Martin Senour #98L-1015
Narva Green - Martin Senour #98L-1013
Last edited by klhansen; 10/13/2026 5:56 PM. Reason: oops forgot Chevy's second green
Page 2 of 2 1 2
Moderated by  J Lucas
