2 members (Peggy M, Pinetree), 81 guests, and 3 robots.
Topics128,232
Posts1,057,818
Members48,477
#1613131 10/12/2026 6:29 PM
I am looking for a part number 3687278 EXSTENSIONFrom the FAM page 5-3.00,
I have the spring on order but need the exstension.
Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
The easiest thing to do is get some spring wire and fabricate that extension. You just need the original length.
Shade Baby - You could also reach out to fellow 'Bolter "KCMongo" at 816-265-1462. He most likely has what you need, wink
~ Dan
1951 Chevy 3 window 3100
It's 10 1/2" long. I made mine from a wire coat hanger. I over thought it for days...! The coat hanger wire is plenty strong and mine has been working for 3 years.
Mike
1953 3100
The Gray Ghost
My Project journal
I use TIG welding feed rod. It is hard to bend, thus hard to straight back out. Work fine, last long time Joe.
Coat hanger wire is a good choice. It's harder than bailing wire so stays in place after it's bent. I use it (among other things) for hanging parts to be painted, even used it to hang up my tailgate when I painted it.
