0 members (), 101 guests, and 3 robots.
Topics128,113
Posts1,056,619
Members48,450
#1612945 10/09/2026 8:22 PM
Former BMW Rider
Former BMW Rider
I've been stewing over this tailgate for years and I'd like to straighten it up and remove the dents. Many people tell me to leave it alone and like the 'patina', but I'm not so sure. It doesn't have to be perfect, just better.
I'm looking for suggestions on how to approach this project. Let me know your thoughts, thanks!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Mine was and still is bad I had a big dent on the top that I could not beat or heat it out so I ended up welding a piece of metal overtop like a second skin .I wish I would have drilled the spot welds out and bent it back to get access to the back ,I seen someone do that on a video and it worked out good .First you would have to straighten the tailgate so it is flat and before drilling the spot welds out your dents may come out by welding some washers so you can use a slide puller to get them out .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Show us pictures of the rest of the truck so we can make better suggestions.
If the rest of the truck is beat up, leave it alone. If the rest of the truck is really nice, by all means bring the tailgate up to the standard of the rest of the truck.
The beat up nature of Ol' Roy in general means the tailgate is staying the way it is. Notice the square angle iron welded to the bottom to repair rust damage (presumably). On the plus side I paid $10 for that beat up 1950 license plate instead of $100+ for a nice one that I would have had to get if the truck were all frou frou.
1950 Chevrolet 3100 (Ol' Roy)
Former BMW Rider
Former BMW Rider
KEVINSKI, I have straightened the tailgate since those pictures were taken. It was slightly binding on the rear cross sill and now moves smoothly thru the full range of open/closed. Any chance you could send me a link to that video? That's the approach I had in mind.
Otto Skorzeny, will do. It's a 'twenty footer' and runs like a top. I drove it to the MBA Roundup last month in Independence, MO. Here's some pics for your viewing pleasure....
Andy
It's pretty nice but not perfect. Therefore, how would you repair the tailgate? If you do it properly (which is the only way to do anything) it will stand out like a sore thumb. You'll have a nice, shiny, new-looking tailgate on a nice, but worn truck. I see no point in doing a half-arsed job on the gate to bring it up to a mediocre standard.
If you ever repaint the truck, fix the gate at that time.
I kind of agree with Otto on waiting till you paint the whole truck. You might be able to spot paint the tailgate, but it would be tough to match the rest of the truck.
In order to fix the tailgate dents (first pics you posted) it would probably be necessary to drill out the spot welds holding the end piece on the left side so you have access to put something like a pipe inside as an anvil. I did a similar thing on my bedsides (a ball bearing on a slide hammer with marks to get the ball in the right place from the end) but that already had an open end. The tailgate is 16 gauge (or thicker) and would be hard to work without some heat. You might be able to weld puller points in the dents and use heat to pull them back up. Here's some pics of my tool I used as an anvil on the bedside rolls.
BTW, your tailgate looks awesome compared to mine when II got the truck, it became a wall hanger. (more pics)
I found the video it was by Carter auto restyling took some screenshots of how to find it ,it is under buyer beware then there are 26 videos one of is about the tailgate ,hope this helps
"The Journey"
Follow in the DITY
Here's the direct link to that video where he reconstructs the tailgate.
www.youtube.com/watch?v=h7dMY-GobMM
He basically took it completely apart and straightened it piece by piece. He might have been better off rolling new top and bottom pieces from new metal, but that's not where he's at. He's restored many things I would have sent to the junkyard.
I’m still watching this video, very fun to watch and satisfying.
At the same time, I just spotted this GMC with what could be the same tailgate!
Though, probably less rusty.
https://www.craigslist.org/view/d/missoula-1952-gmc-pickup-truck-4-ton/6ZyShAv2qAFbYJvk9Jcjpz
Hope this doesn’t violate the thread rules, but they directly co-relate!
Last edited by Steelonsteel; 10/10/2026 2:32 AM. Reason: Maybe not allowed in this thread
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
It all depends on how handy you are Andy...
To me, that looks like a miserable task any way you would go about it.
Even if you drill out the one hundred or so spotwelds, Those dents are deep and irregular. That means there is a lot of stretched metal to contend with. Not fun even if one is good at shrinking metal on curved, thick sheet metal.
