0 members (), 114 guests, and 1 robot.
Topics128,105
Posts1,056,541
Members48,448
#1612847 10/08/2026 5:28 PM
I have a 53’ 3100 with a 235 engine. My problem is the Carter YF carburetor has been rebuilt more times than Phyllis Diller’s face. It is a manual choke and an oil bath air cleaner sits nicely on top. Are there any options besides getting a rebuilt one and hoping I’m not just inheriting someone else’s problems? It doesn’t look like Holly or Edelbrock make anything that will work.
Thanks in advance for any help or suggestions.
Jerry 53 #1612849 10/08/2026 5:57 PM
S Online: Content
Well, there’s always the Rochester B.
As our leader here has said “ Thousands of them still soldier on atop Stovebolt Sixes around the world”.
And they’re easy to find and to rebuild.
Hope I’m not stirring up the dreaded debate on this, in an already polarized world!😂
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Jerry 53 #1612851 10/08/2026 6:43 PM
I rebuilt a Carter YF about 4 years / 10,000 miles ago with a proper kit from Jon/carbking/The Carburetor Shop. It was easy to do and has been working perfectly ever since on E-10 fuel exclusively.
Unless you know for a fact that all the parts on your carburetor are correct for your engine, you might be trying to rebuilkd a Frankencarb with incorrect metering rod, etc.
I originally had a YF with 1950s and 1960s Willys parts that was not correct for the Chevrolet 216.
Once I got that situation resolved, rebuilding it with CORRECT parts from The Carburetor Shop, it has performed flawlessly.
Post all the numbers on the bowl, base, etc. here so that Jon/carbking can determine whether or not you actually have a YF that's designed for a 235.
What kind of problems are you experiencing?
1950 Chevrolet 3100 (Ol' Roy)
Jerry 53 #1612857 10/08/2026 8:25 PM
I also rebuilt the Carter YF that came on my 216 with a kit from carbking. And he also advised me on increasing the diameter of the metering jets to account for the increase in displacement to about 230 when I installed a 235 crank in it. Works very nicely with no issues. A YF for a 216 will have 964S stamped on the body, while a YF for a 235 will be stamped 210(x)S
Jerry 53 #1612861 10/08/2026 8:43 PM
There are lots of Carter YF rebuildable cores on Ebay for AMC 232 six engines. They should be very close to correct calibration for a stovebolt 235.
www.ebay.com/itm/188355409503?
Jerry 53 #1612863 10/08/2026 8:51 PM
Manuel choke carbs are difficult to find and the ones on e bay are hit and miss as far as the proper parts and the ones that are proper go for a lot .First I would identify what Carter carb you have then take it from there to see if you have a good core ,I think they can be rebuilt over and over as long as the core is good .They do seem to be a popular carb for the 235 .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Jerry 53 #1612874 10/09/2026 12:27 AM
What symptoms are you experiencing? I wouldn't give up on that YF yet.
Jerry 53 #1612881 10/09/2026 1:24 AM
U
U Online: Content
I first ran a Rochester B on my '60 235 and switched to a Carter YF 2100. I struggled with the Rochester - long starting while cranking and cranking the starter, had to feather the gas pedal to raise the rpm at stop signs/lights, too much gas pedal and it would die,... On the other hand, the Carter has been a blessing. Stomp the starter for one second and my engine starts right up, push on the gas when taking off at stop signs/lights with no issues,... Also, I converted my oil bath air filter to a regular paper element.
~ John in Utah
Here We Go
Follow in his DITY Bay
Jerry 53 #1612898 10/09/2026 4:09 AM
Carburetion specialist
Interesting analogy on the number of times rebuilt, cannot say I have ever seen that analogy before.
If shiny / new is your goal, there are a number of import carburetors currently available that are advertised for the 235. Sometimes they work, sometimes they don't, never really well.
WHY has your carburetor been rebuilt so many times ? 1/2 a million miles on the carburetor? Once done by a commercial rebuilder with mismatched parts ? Rebuilt with a typical FLAPS "rebuilding kit" with incorrect parts ?
Opinion - THERE IS NO BETTER CARBURETOR FOR YOUR 235 THAN A PROPERLY REBUILT CARTER THAT CARTER DESIGNED FOR THE 235 !
Possible problems:
(A) 1/2 a million miles and the throttle shaft needs replacing and the throttle body needs bushing - just do it
(B) Mismatched parts - identify what you have and correctly match the parts (especially the metering rod and main metering jet)
(C) FLAPS "rebuilding kit" with Ford fuel valve (Ford used an orifice of 0.101 while Chevrolet used an orifice of 0.081, plus the Chevrolet valve should be spring-loaded).
(D) Electric fuel pump with too much pressure (3 psi is sufficient).
As has been posted earlier in this thread, determine WHICH YF you have, and its applicability to the engine. If the correct application, just fix it.
Jon
The Carburetor Shop
