1 members (1 invisible),
111
Mod | | | Forums66 Topics128,261 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 51 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 51 | The parking brake on my 1949 3100 is stuck and won’t release.I can’t get the drum off so any tips would be welcome as well once I can access the brakes any suggestions for a fix would also be appreciated. Thanks
1949 3100
| | | | | Joined: Oct 2021 Posts: 7,030 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,030 | Start banging on the drum with a blunt force hammer - HARD.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | A little heat on the drum near the studs might help.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2021 Posts: 280 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 280 | Have attempted to rock the truck back and forth? I’ve had the case where the emergency brake released but the brake was frozen and doing what I suggested released the brake shoe. | | | | | Joined: Dec 2010 Posts: 51 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 51 | Thanks for the great suggestions…have tried all three
1949 3100
| | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | It's also possible that the cables are rusted up and or frozen. Try some WD40 or other product on the cables and the contact points on the mechanism. Loosen or disconnect the cable to see if that is the problem. Fred
| | | | | Joined: Mar 2021 Posts: 280 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 280 | I assumed you’ve already back off the shoe adjuster all the way? Spray WD 40 or Rust Buster into the brake shoe adjuster? At this point you’ve got not much to loose Let me add my last thought and if you’ve already do this ignore me: You have Huck brakes? Have you disconnected the parking brake cable at the cable support just aft of the parking brake cross tube? If not when you do does the coaxial cable move in the outer sleeve? Pour rustbuster into the outer sleeve and try to get free play. It may take a few attempts. If the coax cable moves freely then you may have to take more aggressive actions like a) release the wheel brake cylinder and see. When we first started working on our 1948 3100 our left rear brake was twisted and broken the right one just frozen. Best of luck!
| | | | | Joined: Dec 2010 Posts: 51 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 51 | Actually I haven't tried those last two suggestions...THANKS!
1949 3100
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Its a fairly thick and stiff cable. Hit the end of it with a hammer after you let the rustbuster stuff soak for a day or two.
