8 members (delwrench, crenwelge, 2-Ton, Cletus1950, Jay R, Hugh63c10, 1955 1 Series, amtrakjoe), 338 guests, and 6 robots.
Topics128,159
Posts1,057,027
Members48,460
#1612768 10/07/2026 12:04 PM
AC Delco part # D111 GM# 12338947 will not fit in my 1962 235 motor I have never had this issue before. The slot for the excentric screw is to far away from the bottom contact. Are there 2 different distributers?
AD Addict & Tinkerer
I ran across the same issue with my ‘59 235. There are two different distributors but not for the same year. Early ones (short cap) were for the low pressure 216 and same year 235’s. Later ones (tall cap) were for the high pressure 235 and 261’s.
One of our own ‘bolters “Pre ‘68 Dave” is an expert on these Stovebolt engines and has a website that show the differences in the distributors thru the years these engines were made.
Here is that list.
Phil
Project Journals
Stovebolt Gallery Forum
Chris - There should be a distributor number on yours stamped on the breaker plate. If you post that, we can try and figure out which one you have and hopefully help find you the points you need. wink
~ Dan
1951 Chevy 3 window 3100
This contact point has no slot. Worked for me....Standard Blue Streak Contact Point Set - FD8183V
made in north america www.oreillyauto.com/detail/c/blue-s...-contact-point-set/std2/fd8183v?q=points
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
My '62 235 motor has been using Delco Remy D105, set at .018"-.020" for many years. Puurrrrrrrr !
Craig
