2 members (Greg_H, 1 invisible),
106
Mod | | | Forums66 Topics128,263 Posts1,058,136 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 478 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 478 | AC Delco part # D111 GM# 12338947 will not fit in my 1962 235 motor I have never had this issue before. The slot for the excentric screw is to far away from the bottom contact. Are there 2 different distributers? | | | | | Joined: Feb 2019 Posts: 4,531 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,531 | I ran across the same issue with my ‘59 235. There are two different distributors but not for the same year. Early ones (short cap) were for the low pressure 216 and same year 235’s. Later ones (tall cap) were for the high pressure 235 and 261’s. One of our own ‘bolters “Pre ‘68 Dave” is an expert on these Stovebolt engines and has a website that show the differences in the distributors thru the years these engines were made. Here is that list.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2009 Posts: 6,154 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,154 | Chris - There should be a distributor number on yours stamped on the breaker plate. If you post that, we can try and figure out which one you have and hopefully help find you the points you need.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2020 Posts: 1,985 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,985 | This contact point has no slot. Worked for me....Standard Blue Streak Contact Point Set - FD8183V made in north america www.oreillyauto.com/detail/c/blue-s...-contact-point-set/std2/fd8183v?q=points
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Jan 2002 Posts: 2,850 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,850 | My '62 235 motor has been using Delco Remy D105, set at .018"-.020" for many years. Puurrrrrrrr !
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
