9 members (Chip O, Bill Hanlon, J Lucas, dt235sd, Gdads51, Hotrod Lincoln, tclederman, 2 invisible), 76 guests, and 0 robots.
Topics128,205
Posts1,057,427
Members48,471
I have a 56 Chevrolet 235 12V that is rebuilt and ready to start. I am looking for suggestions on a generic alternator to use on it. It is on a start cart so I am not looking for harness adapters etc., the buyer may elect to use a different alternator in their vehicle. Does anyone have any ideas? I have brackets from the 9 o'clock position, but I can fabricate whatever is needed. I have heard a 7127 single wire would work, but I have had very good luck on this forum in the past so any input is greatly appreciated. Thanks in advance!
55 GMC 3100 2nd Series
71 GMC 1500 Super Custom
1956 Thriftmaster
1954 Blue Flame
1962 Thriftmaster
Delco-Remy 10SI . Internally regulated. It 's available in one wire and 3 wire
1950 Chevrolet 3100 (Ol' Roy)
U
U Offline
I'm using this 12v alternator (from Autozone) on my '60 235 that I swapped into my '46. It is not a one wire.
~ John in Utah
Here We Go
Follow in his DITY Bay
B Online: Content
I'm not a big fan of a one wire alternator in a vehicle, but it should work fine in a start cart. 7127 is what I use on my truck, but it is wired as a 3 wire system.
H Online: Content
The only thing necessary to make a 3 wire setup work with either a 10-SI or a 12-SI alternator is an idiot light or a diode in the circuit to prevent run-on from feedback to the ignition system on shutdown. See the photo above- - - - -the white wire in the pic is the one that needs a diode. I use a small 2-wire peanut bulb socket with a red lens (not a LED) on my tractor to provide the excitation to kick off the charge.
