4 members (NJC, Otto Skorzeny, Wally / Montana, 2-Ton), 66 guests, and 3 robots.
Topics128,263
Posts1,058,134
Members48,482
Ok,
I'm stuck . How does the passenger latch come out / free of the door on my 1950 3100?
Seems like everything is apart?
Thank you.
Todd
1950 Chevy 3100
With the window all the way up, the latch should fall down to the bottom of the door and then out the lower opening. No?
Craig
Just because I can't see from this one picture, did you remove the exterior key lock mechanism? headscratch
If every other pieces of hardware securing the latch to the door is removed, from what can be seen in this picture, that's the only thing I can think of to possibly keep it from coming out.
~ Dan
1951 Chevy 3 window 3100
Dan probably has the solution. The key lock has to come out. It's held in place by a sheet metal keeper that's under the weatherstrip. Here's the page from the service manual.
I totally forgot about the door lock and its metal keeper.
Craig
The Lock is OUT . The handle removed. All screws are out.
It seems like the metal window channel? Is holding it in place?
Todd
I'll try and get a picture.
1950 Chevy 3100
Todd - Snap shot from the 1948-51 Chevy Shop Manual. I think you skipped step # 3. wink
~ Dan
Dan, correct!!!
I did not remove it...
I guess I'll do that tomorrow.
Thank you.
Backstory: the door started to "Click" open while driving. The door was still "Closed" but half open is the way I can describe it..
Latch is loose.. it's either broke or worn out.. I know I replaced a spiral spring or two but I don't remember if it was the Driver's door or Passenger side latch.
1950 Chevy 3100
Sounds like the lock is worn and releasing to the safety catch. When you get it out, check the areas marked by the arrows on the attached. The lever shown with the red arrow should have a sharp corner on it where it contacts the latch cam, and the latch cam (yellow arrow) should have noticeable serrations along it. That's what keeps the latch cam from rotating and releasing. I think that if you lock the door with the inside handle that also prevents the latch cam from releasing.
I forgot about having to remove the window run channel as well.
Kevin,
Thank you.
I'll probably remove t tomorrow.
I will update.
Todd
PS So far this part is loose (it wiggles) the driver side does not move. See picture.
1950 Chevy 3100
That cage (for lack of a better term) that your arrow was pointing at was also loose on one of my latches. It holds the outer bearing for the latch cam (the part that grabs the striker) and is staked in place. I hit it with a tack weld when I rehabbed my latches. (Pic 1) I also built up the part of that piece that rides up on the striker. (Pic 2) I would definitely do that once you get the latch out. You'll be able to see how it's secured to the latch body. I built up the safety catch as well. Most of the work was on the driver's side latch as it got way more use, of course. I think there's a post with more pics of latch repair in my Project Journal.
Time for Altman latches? Best thing I ever did for my truck.
I'll bet that door has worn out hinge pins and is sagging quite a bit, causing that door latch to hammer the striker when the door is slammed shut. You can clean that hammered piece and weld some metal back in and weld the piece back on.
I'd rebuild the hinge first so that you don't bang into it anymore.
Once you have the hinges rebuilt, put the door back on and adjust it until the belt lines of the cab and the door match up
Do this before you replace the door latch and striker.
Here it is:
Broken welds and Bent? Looks pretty far off from the tack weld .Thoughts?
See pictures.
Todd
1950 Chevy 3100
I think that might be fixable, although it looks a bit bent. That divot in the latch cam can be fixed by the spring pieces that the vendors sell. It looks like something I'd attempt to fix with questionable results.
But your best approach might be to post in the Swap meet to see if someone has an original passenger latch in better condition.
Kevin,
Thank you. I'm a bit confused since the passenger door is rarely used.
I have a spare 1950 passenger complete door. I am going to pull out the latch and see how it looks. I'll update in a bit.
1950 Chevy 3100
Here is the Spare latch. Seems a bit straighter . It needs two weld tacks. One broken and loose on other area.
Otherwise seems to work ok.
Any thoughts?
1950 Chevy 3100
That spare looks to be in a lot better shape and should work well once you get it tack welded. As Carl said, check out the hinges. That may be the cause of that first latch being so beat up. Yeah, my passenger door latch was in much better shape than the driver's side, but maybe your passenger door got used much more.
What am I checking on the hinges? I don't see any "Obvious " sag...but it probably doesn't take much.
Breaking out the welder now.
1950 Chevy 3100
Check for play at the hinges. If the pins are worn or seized in the bar that attaches to the door (very common) the pins will wear into the cage that bolts to the door pillar. If the latch end of the door will move up and down when open, it's probably time to remove the hinges and check them out. My door hinges weren't too bad, as far as looseness, but when I remove the doors and hinges, the wear was revealed. I rebuilt them with new pins and drilled the bars attached to the doors for bronze bushings and used oversized hinge pins. I also replaced the faceplates on them as they were bent a bit at the margins from the door opening a bit too wide.
Kevin,
Thank you.
Here is the Spare latch now.
Seems much better.
1950 Chevy 3100
When you close the door without the latch installed, does the belt line in the door line up with the belt line of the cab front and back? That will give you an idea of if your door has sagged from worn out hinge pins.
If the belt lines match, then your striker was way out of adjustment.
Ok, The belt-lines line up, hood side and rear cab side.
The striker was not 100% tight, the clutch screws. Now solid.
76 years of rattling down dirt roads?
Todd
1950 Chevy 3100
As Panelfan would say, "Bob's your uncle eh?"
