1 members (mason86),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16123 01/29/2002 6:06 AM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Y'all I am removing the loud gear drive from my 283 cam and converting it back to stock chain drive is there any thing I need to watch out for? Judd Pease http://sjmodels.railfan.net | | |
#16124 01/29/2002 6:54 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Depending on the type of set-up, you might have some problem lining up the pulleys.Should not be too much problem. On your new chain and rear set, just make sure you have the #1 cylinder at TDC and line up the timing marks on the gears. Should be fine unless you get into degreeing the cam.
WHat are you going to do with the gear drive set-up????
#16125 01/29/2002 7:32 AM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | is there any thing I need to watch out for? Yes. People running up your driveway trying to get you to sell it to them at what they think is a good price.
'67 GMC 3/4 292 4spd
#16126 01/29/2002 1:58 PM | | Anonymous Unregistered | | Anonymous Unregistered | Just make sure it was just a gear drive setup(4 gears) if it has 2 gears you need to change the cam and the dist gear ,cause it is a reverse rotation cam.  | | |
#16127 01/29/2002 8:59 PM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Y'all Thanks for the help! It was a 4 gear set up and I swapped it to a friend that works at part store for stock parts etc. Gave him a deal for his 55 Chevy hot rod now he owes me. LOL Judd Pease http://sjmodels.railfan.net | | |
#16128 01/31/2002 12:12 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | especially since the stock set-up goes for around $15.00 and the gear drive set goes for $125.(new)
