0 members (), 81 guests, and 4 robots.
Topics128,211
Posts1,057,475
Members48,473
What are the correct nut and bolts size's for mounting a 235 starter including NCT or NFT
Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
See the info under parts group 2.077 on this page of the 1957 Chevy Master Parts Catalog
~ Dan
1951 Chevy 3 window 3100
The stud threaded into the bell housing 1/2-13 and 1/2-20 where the nut threads on.
The bolt is also 1/2-13.
Yes that works, this engine I picked up from SC I needed to check the compression. Somewhere along the way I lost the bottom bolt for the starter I removed for testing. Compression results to follow.
Shade Baby
"Back In Time"
Follow in the DITY
