4 members (Pre '68 Dave, Steveoreno, Nick in Manitou, Bill Hanlon), 105 guests, and 1 robot.
Topics128,198
Posts1,057,272
Members48,466
#1612177 09/28/2026 9:01 PM
1956 Chevy 3100 235 straight six:
I bagged what I thought was the hold down for the distributor about a year ago. When setting up the distributor for correct timing today I discovered that the hold down was not correct, but the bolt, washer and lock washer that I had in the bag appear to be correct IF what holds the distributor in place is the advance/retard collar on the shaft of the distributor. I started to attach a large O-ring in the top groove of the shaft, but then decided not a good idea and stuck with just the gasket that seats nicely underneath the advance/retard collar.
So, the question is, is there actually a hold down for the distributor (and no place for it to hold down on the distributor) or am I correct in figuring the advance/retard collar serves as the hold down?
The "hold down" is the part of the vacuum advance unit with the slotted hole called the "octane selector". DO NOT install an O ring in that top groove- - - -it interferes with the free movement distributor housing by the vacuum advance. That groove is there to keep oil from migrating up the housing and it does its job by simply being there- - - - -no seal needed.
Jerry, you are a fount of knowledge extraordinaire. Thanks, as always, for the info. Odd name for the vacuum advance, "octane selector" but thinking about it it makes sense.
Now, just got to figure out where that piece that looks like a hold down goes, lol.
Hawkman - Post a picture of it in a new thread in the Name that part... forum and folks will likely be able to help you figure it out. wink
~ Dan
1951 Chevy 3 window 3100
Moderator, Electrical Bay
Jerry was explaining the slotted hole. There is an image below...it doesn't show everything in clarity, though. You'll have two methods of adjusting timing, actually. One: your distributor will be held by a squeeze clamp which is part of the retaining piece. Unlike the distributor for say a 283 V8 there is no molded stop ring to make certain it only goes in so far. Before you adjust timing and tighten this, please pull up the distributor a wee bit (maybe 1/16") to get the tang just off of the oil pump piece. This clamp allows you to initially loosen and rotate the distributor to establish proper position relative to top dead center and flywheel, etc. And two: there is an engraved line in the center (which should reflect where proper timing for your engine is) and there are engraved lines above and below that line which correspond to advanced or retarded timing (a person could have chosen them to use with higher or lower octane gasoline). Once your timing is set properly using the squeeze clamp, you can adjust + or - your timing by loosening the hold-down bolt and rotating the distributor and that piece (which also incorporates the vacuum advance canister and linkage). Hope this helps.
~ Jon
Jon G - It looks like your pictures didn't attach correctly as the just come up as black screen. Can you try and remove those and reload them?
~ Dan
I've tried that a couple of times...also tried to attach in another post (about steering gear lube). For some reason it seems to happening this way...at least for me. I'll sign out and sign back in and see...
~ Jon
Dan, images attach correctly in the attachment manager but they don't make it to the forum when the post is made. Jon
~ Jon
Understood and thanks for the feedback Jon! I tested in the OOS Swap Meet forum and found the same issue. It's not us unfortunately. frown
A report has been sent to HQ as it appears to be affecting posts in all forums - Big BOOOOO!!!
~ Dan
B Online: Content
Back to the distributor:
Does the Chevy engine use a spacer plate between the block and the "squeeze plate" (the book calls it Distributor Vacuum Control Arm Clamp)? My '52 GMC (uses the same distributor as the Chevy engine) has one. Maybe 1/8" thick with a hole for the distributor's shaft to pass through, another hole for the locking bolt to pass through and a tit to position it in a dimple in the engine block.
This part is not shown in any of my GMC Master Parts Books.
I'd post a picture, but pictures aren't posting right now.
Bill - Picture posting has been fixed. You should be able to add them by editing your post. wink
On the question of Chevy having a spacer plate under the "Octane Selector" assembly, everything I searched this morning (prompted by your email smile ), says Chevy didn't have such a critter. I looked through both a Chevy Parts Book ('54) and Shop Manuals ('42-'47, '48-51 and '54) and not seeing anything like your GMC spacer (screenshots attached).
~ Dan
B Online: Content
Pictures are back, so
Have any of you GMC guys seen this spacer? Anyone seen one on a Chevy 6?
I have one on my '52 GMC 228 between the engine block and the "octane selector". None of my GMC Master Parts Books (1939-60, missing only 55.1) show this part.
The first picture is shown with the "nipple" up, but it actually installs with the nipple down which fits into a dimple on the block. The distributor shaft goes thru the big hole and the same bolt that you loosen to adjust the "octane selector" goes through the smaller hole.
The second picture is from the ’52 GMC Maintenance Manual shows it peeking out from under the octane selector.
Still no dice on the images. Ah, well. No big deal.
~ Jon
I've got a few GMC core engines stashed away-- - -a 228, a 248, and a couple of 270s. I'll see if any of them have something similar.
It's 117 eastern time now and I can see the images
1950 Chevrolet 3100 (Ol' Roy)
works for me,when i click on your image, i get a picture of a distributor in an orange engine.
Here is my solution for my 292.
B Online: Content
Mick:
What turns the oil pump?
Bill - It took a bit of digging through my resources to find info on the GMC "spacer" you're asking about. As mentioned before, Chevy didn't use that. In searching through my GMC Maintenance Manuals and Master Parts Books, the first of my resource books for that piece (actual called an "adapter") show up (I believe) in a 1939 Maintenance Manual X-3902. I again found it in a 1940 Maintenance Manual X-4044, then again in 1947 Maintenance Manuals X-4703 and X-4704. I did look at a 1955.2 Series Maintenance Manual, but that item seems to have disappeared from the diagrams/figures in that and later books as you mentioned.
Then I switched to checking GMC Master Parts Books I have or have access to. I found the "spacer", actually listed as an "Adapter, Vacuum Control" GM# 1882532 listed in a 1945 Master Parts Book X-145020. Also listed in a 1945-46 Preliminary Parts Book X-145021. From their I jumped to GMPartswiki and found GM# 1882532 listed in the GMC 1951 Master Parts Book X-151004 and again in the GMC 1964 Master Parts Book X-164001. I did lastly check my GMC Parts Illustration Book P&SM 165, finding that the piece is not displayed or listed in the exploded distributor diagram.
I've included pictures of all this info (except the P&SM pic as I ran out of space to attach) below in the hopes that it might be useful and/or of interest to fellow 'Bolters.
All this said, my apologies to "Hawkman" for taking your thread off on this tangent. Hope I didn't cause any confusion. wink
~ Dan
Mick:
I have a 5 stage dry sump system. The pump is powered by a belt off the crankshaft. It's got a pressure regulator to set the desired oil pressure. I have to make the mount yet. I bought a bunch of billet aluminum before the tariff mess maybe I'll do that next
B Online: Content
At 18:54 CDT most (but not all) pictures in this thread are no longer visible.
Dan, no apology needed. I found the extended conversation interesting. Read through it all to make sure it didn't apply to me. I will take a picture tomorrow of my distributor hold down setup in case anyone sees a problem with it plus a picture of what I thought was the hold down that started this thread. Thanks, all!
(Good news is I have finished painting the firewall and am ready to slip the frame/engine back under the cab and start assembling all the hook-ups there. Yea!)
Thanks Hawkman! That is real good news! Woohoo yahoo
Looking forward to seeing some pictures if you'd care to share them. wink
~ Dan
Here is a two shots of the distributor octane selector which I hope is correctly installed. Also, the mystery hold down that doesn't hold down my distributor. Included is a shot of the painted firewall using a shake and rattle spray can of the approximate color I will be spraying the truck.
Distributor, mystery hold down and painted firewall
Isn't the grease cup supposed to be on the rear of the dizzy, behind the vacuum canister instead of over it? Was the design changed on later model dizzies?
B Online: Content
Towards the rear of the truck is how mine is mounted. Also the stud for the coil - wire to the distributor is typically pointing toward the right side of the truck where Hawkman's is pointing left. But other than making it harder to get to these places, there is no reason you couldn't mount the distributor that way as long as the plug wires are mounted properly in the distributor cap.
Looks like someone stole his dipstick handle.
That's what I thought.
Well, Bill and Otto, I thank you for pointing out the obvious misalignment on the distributor. I pulled all the wires from the distributor, corrected the misaligned items you both pointed out which made a lot more sense. Then I restabbed the distributor, noted the location of the rotor, tightened bolt and screw, then rewired the distributor according to the firing order. Tomorrow I will pack the grease cup with grease, which I failed to do today. Hopefully, all is well now and we can put this thread to rest.... before I start another one, lol.
Again, thanks guys!
