2 members (78buckshot, Wheelie), 131 guests, and 2 robots.
Topics128,128
Posts1,056,358
Members48,441
#1612081 09/27/2026 11:21 AM
Moderated
Moderated
I've been trying to find a good useable RH Spindle for a 1956 chevy 3100. I'm from the east coast which doesn't help much. I've read that some folks performing upgarades throw these parts in the trash even though they are useable. Can anyone suggest how I may look more toward the south west area for better results?
Welcome to Stovebolt Paul! wave
Your first post is more an ask for help on locating/finding the part you need, and should really get moved to the Truck Parts Wanted forum where we can go to work to help you find what you need. That being said, I've gone ahead and moved it there so we can get busy with that help! thumbs_up
While we do that, it would be great if you started a new post in the Welcome Centre, introducing yourself and your truck to the community. We'd love to hear and see (post pics please - wink ) what you'd like us to know about you and your truck.
Once again, Welcome to the 'Bolt. We'll get to answering your question pretty quick. smile
~ Dan
1951 Chevy 3 window 3100
I’m pretty sure the AD 1/2 ton spindles and the task force spindles interchange. Can someone confirm that is true?
If so, I might be able to assist.
1951 3100
Paul - I recalled doing some research awhile back on the spindle you seek for another 'Bolter.
Here's some relevant info that should be helpful to you in finding another spindle:
The spindle (steering knuckle) that fits your '56 (1951-57) is GM# 3709756 (forged piece with casting# 3708831).* Same spindle used for both left and right sides. See this page from the 1929-57 Chevy Master Parts & Accessories Catalog:
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0523.htm **
* NOTE: In the 1929-54 Catalog, their are a couple different GM#s for earlier versions of the spindle that are noted to fit '51-'53 (GM# 3696337) and '54 (GM# 3709756) steering knuckles for those 1/2 ton trucks, but from what I can tell the '51-'53 number was replaced by the GM# 3709756 listed in the 1929-57 Catalog. It is a "possibility" that you may stumble across someone offering one of the early numbered parts. If you do, it would work for your application as well as the newer numbered part GM# 3709756.
** NOTE: In the 1979 Chevy Master Parts & Accessories Catalog, GM# 3709756 is also listed for all '51-'59 1/2 ton trucks. See this page:
http://www.gmpartswiki.com/getpage?pageid=22515
With this info, you can widen your search of trucks to hopefully find another spindle. More likely than not, your best bet will be to find someone offering a complete front axle. With that, you get two spindles to chose from to use to replace yours. wink
I'll be back soon with some possible sources near you, if I can find them. thumbs_up
~ Dan
Nathan - They do as seen in my reply I posted just after yours popped up. That would be cool if you can help Paul out. Will have to wait until he come back as being new and moderated, he can't receive PMs yet. He does however have a direct contact listed in his profile, so that can be another way to communicate while he gets through being moderated. wink
~ Dan
A little late, but ...
1955-59 GMC 1/2 ton without 4 wheel drive use a GM F022 front axle. The 1955.2-60 GMC Master Parts Book lists part number 3709756 (casting # 3708831) for both left and right side, just as Dan quoted from the Chevy catalog. Steering arm would be different of course.
The earlier 1947-54 GMC Master Parts Book lists 3696377 for both sides on 1950-54 half ton trucks, but notes "when stock is exhausted use 3709756".
I don't have 1955 first series parts information, but if before and after are the same I would bet that the 55 1st is too.
I’d have to do some wire wheeling to get a part #, but what I have is from a 51 3100.
1951 3100
Moderated
Moderated
Hi and thanks for helping me with the spindle/knucle issue. It took me awhile to figure out how to replay and thank you. I'm learning how to navigate around a bit but didn't wish to rude and not thank the people who responded/helped.
I'll spend some time describing my 1956 Chevy 3105 Panel Delivery Truck once I figure things out.
No worries Paul and looking forward to seeing and hearing about your Panel! thumbs_up
On a related note, take your time on posting as we are currently experiencing a problem with pictures posting/display in the forums.
PS - When I get a chance later, I'll see what might be currently offered on FBM etc. to see if there's anything somewhat local to you.
If I find something I'll post the links in another reply. wink
~ Dan
Moderated
Moderated
Thank you Dan, I really appreciate your time and efforts. Finding parts for a 1956 Panel Delivery in the east coast is difficult. I wanted to replace the hub as well but I haven't proved anything is wrong with it.
I converted the front bearings to tapered bearing as recommended. The is something not quite right in the RH side. The hub rolls free and and then binds a bit. When I tighten the nut to where it should be it gets worse. If I loosen it there is too much play.
I have a friend who is an expert mechanic coming on Oct.1 to help determine what's up.
In the meantime, how do show and talk about my Panel? It's not in my profile or anything, right?
How much is "tighten the nut to where it should be"?
Paul - I'm going to answer your last questions first. A reply from you to Bill's question will perhaps help diagnosing the problem. wink
You can add a "signature line" by updating your profile (see what is displayed in the bottom of all my posts for just one example) that can provide the basic description on your truck, like make, model and some other descriptive stuff. Doing this automatically places that signature line in every post you make, making it easy for folks to know what truck you are talking about in your posts and questions. Only note to remember on that is if you're asking a question not related to your truck, be sure to mention that in the post title so folks don't get confused on what truck your trying to discuss.
For a more detailed next step, the best way to introduce yourself and your truck, including posting pictures to show it off (in whatever condition it may be in smile ), is go to the
Welcome Centre and create/post an intro there. Since you already have 4 approved posts, your next post will not require moderation, so it will automatically display, along with your updated status as a 'Bolter! thumbs_up
Looking forward to seeing your intro in the "WC". smile
~ Dan
