Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (78buckshot, cmayna), 111 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
Page 2 of 2 1 2
Rock49 #1614243 10/29/2026 4:37 PM
Those two at the bottom of the bore would actually be the easiest to get moving, with the geometry of the crank position. Turning force on the crank would be multiplied many times with pistons at BDC or TDC. But the others at mid-stroke would have the least mechanical advantage and would keep the crank from turning. Once disconnected from the crankshaft, each piston is an independent problem and usually will move without too much problem. On mine, even that one that was really stuck moved until it got to the top of the bore where there was too much rust and crud. I suppose I could have wire brushed the bore like you did and had better success, but I got it done with the brute force method.
Rock49 #1614247 10/29/2026 5:02 PM
I do believe this will end with brute force.
Im just not to that point yet.
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Rock49 #1614259 10/29/2026 7:15 PM
Originally Posted by Rock49
I Of course the engineer who designed the bell housing attachment was clearly a Bond villain.
Sneaky trick here- - - - -use about a 3/4" or 1" diameter hole saw and poke a few holes in the bell housing adjacent to the clutch bolts you can't reach. Then use a universal joint socket to remove the bolts. That just leaves a few "clutch cooling holes" in the bellhousing, and it can be reused. You can even plug the holes with rubber expansion freeze plugs if you choose to do so.
Rock49 #1614374 10/31/2026 12:24 AM
Well I got the bell housing off today. Tomorrow I will put it on the stand and flip it to start on the bottom end. I also spoke with a local machine shop. They will do the machining and I put it together, so for now that's all lined out.
The engine will not go through a full rotation. Pistons 2-4 will move up and down about an 1 1/2 inch when I rotat the pully by hand . 1 and 6 do not move at all. 1 and 6 move with persuasion.
I would think all 6 pistons should move. So I'm preparing for some disappointment when I get the oil pan off.
Also the hydraulic lifters will not come out. there is play, they just won't pull out. I did not get vigorous with them though.
My plan of action for the lifters is to remove the cam. then tap out the lifters from the bottom.
Or do the lifters have to out to remove the Cam?
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Rock49 #1614388 10/31/2026 1:14 AM
AD Addict & Tinkerer
P Online: Content
You’ll need to remove the lifters or lift them at least higher than the cam or the cam lobes won’t clear the lifters.
Phil
Project Journals
Stovebolt Gallery Forum
Rock49 #1614416 10/31/2026 2:08 PM
Thanks Phak1. I will keep that in mind.
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Rock49 #1614480 10/31/2026 11:32 PM
Well today piston #1 declared squatters rights and refused to move and the camshaft thrust plate was broken. Other than that everything went good for disassembly.
The bearings were worn but I did not note any pitting or scratches on the crankshaft wear surfaces. The camshaft did not look bad to me, but what do I know. The lifters had a little surface rust on the perimeter but bottoms were shiny and flat. So it looks like the bearings did there job.
Tomorrow when I have better light I will take photos of the rod and main bearings as well as the camshaft, lifters and crankshaft.
Have a good day.
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Rock49 #1614524 11/01/2026 7:03 PM
Block is completely disassembled minus the dip stick tube.
Wiped off the camshaft and noted pitting on all the lobes See Pic.
On the crankshaft everything was smooth except where the thrust bearing is located, there is a grove I can barely catch a nail on.
I also took a Pic of the camshaft # for those interested.
3752736
rod bearings were all worn to copper.
Any recommendations for removing the dipstick tube?
Have a good day
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Rock49 #1614527 11/01/2026 8:22 PM
Slip a bolt into the top of the tube- - - - - -I believe a 1/4" is about the right size. Then clamp a pair of vise grips over the area where the bolt is inserted and tap on the underside of grips with a hammer to slide it out of the block. Another way to do it is to slide a big socket over the tube before you insert the bolt, and use it like a slide hammer.
Rock49 #1614532 11/01/2026 9:36 PM
Jerry's ideas would work. When I removed the dipstick tube I used a drift punch that fit closely in the hole and tapped it out from the bottom.
Rock49 #1614563 11/02/2026 2:28 AM
Thanks Jerry.
Did what you said, fast and easy.
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Page 2 of 2 1 2
