2 members (2-Ton, NJC), 68 guests, and 3 robots.
Topics128,263
Posts1,058,134
Members48,482
#1611906 09/23/2026 10:44 PM
Working on the horn. Pulled the button and noticed that I was missing my Contact or contactor brush. Replaced the brush and realized the the insulator wasn't Insulating. So with the help of a drinking straw I fix the insulator. However, when I turn the wheel there is a spot that will sound the horn. I am guessing that it is the Horn bearing that has a short in it. How do I know or test this before ordering a new one.
Thanks for all your replies
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
AD Addict & Tinkerer
I honestly wouldn't suspect that the bearing is shorting out, especially given that the horn only blows in one specific spot as you turn the wheel.
Before doing anything more drastic, I would strongly recommend replacing the insulator. The proper insulator is designed with a specific shoulder that keeps it from contacting the bearing. Using a makeshift fix like a straw likely won't be up to that task and will probably lead to the same issue recurring.
Replacing the bearing is not an easy task as they are usually stuck after being installed for seventy years or so.
Phil
Project Journals
Stovebolt Gallery Forum
