4 members (Peggy M, Mike B, jaycoop, 1 invisible),
75
Mod | | | Forums66 Topics128,266 Posts1,058,143 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Working on the horn. Pulled the button and noticed that I was missing my Contact or contactor brush. Replaced the brush and realized the the insulator wasn't Insulating. So with the help of a drinking straw I fix the insulator. However, when I turn the wheel there is a spot that will sound the horn. I am guessing that it is the Horn bearing that has a short in it. How do I know or test this before ordering a new one.
Thanks for all your replies
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Feb 2019 Posts: 4,531 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,531 | I honestly wouldn't suspect that the bearing is shorting out, especially given that the horn only blows in one specific spot as you turn the wheel.
Before doing anything more drastic, I would strongly recommend replacing the insulator. The proper insulator is designed with a specific shoulder that keeps it from contacting the bearing. Using a makeshift fix like a straw likely won't be up to that task and will probably lead to the same issue recurring.
Replacing the bearing is not an easy task as they are usually stuck after being installed for seventy years or so.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
