2 members (DES57, 1 invisible), 142 guests, and 2 robots.
Topics128,153
Posts1,056,827
Members48,456
#1611621 09/18/2026 5:35 PM
Went to start my 51 for the first time in too long today. Promptly broke the middle out the visor or socket. I guess it seized up a bit and I went too hard.
My visor itself is good. Just need the metal bits. Would prefer old GM to new aftermarket.
Let me know if you might have one…
1951 3100
I know where there's one in CA, but it's for a later model (62-66) Chevy truck. I assume you need the left side, which I believe is what that one is.
If you want it, it may work (the difference may just be color) and it's yours for the price of postage. I'll be where it is next week.
Sounds good. Let me know.
Yes, driver side.
1951 3100
Nathan - Lots of our regular vendors offer repops listed to fit 1947-53. Jim Carter has UPV131, while Classic Parts offers 25-011 for a lesser price.
I thought I had one (something I picked up at an antique store cheap), but in checking the part number, it turns out it's listed for a 1954 model year. Different number than the 1947-53 original part number. No idea if there is a difference in the mounting to the earlier part as I haven't tried to compare it to the one installed in my truck. Perhaps someone knows if there really is a difference, or if it might work in the earlier trucks?
If it would work in your truck, we can talk further. wink
~ Dan
1951 Chevy 3 window 3100
Here's a couple pics of the one I have (in CA.) Looks pretty close to the one that Dan has.
I was interested to see the notation "NEW ENGINE 21650 MILES" on the visor. headscratch
Kevin, that definitely a different mounting pattern. Appreciate the offer though.
1951 3100
I saw one on eBay listed as 54-55 and figured seller was wrong. Interesting.
Mounting bolt pattern looks the same. Maybe the spring loaded portion was a new feature? Or the length?
1951 3100
Yep, on second look at Dan's and mine, they're definitely different.The angle of the pivot point is likely different as well. Good luck on your search.
