Anyone have experience troubleshooting and replacing the backup switch in a 1966 C10 with 3-speed transmission? My truck has been… modified. Some previous owner installed a toggle switch. In looking online I’m not seeing what I expected to see. Thanks!
The switch Kevinski pointed out is correct, presuming you still have the 3 speed column shifter on your truck. If your truck got modified by the PO with a floor shifter, that takes the column switch out of the equation.
Yes, still column shifter, or no?
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Yep. I am not sure how many models/year run they did that, but there was that half donut horse shaped thing that sits on the column, above the floor and it rotates as you shift.
