Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
1 Offline
https://www.facebook.com/marketplace/item/28097341196566510
Selling a 1958 (not exactly sure of year but late 50s vintage) GMC fire engine. Not running, but complete with all parts/pieces.
I think it is a 1955.
Not my ad. Posted for your convenience.
The S in the serial number makes it a 58 or 59. The engine is a 371 inch Oldsmobile.
1 Offline
The logo on the valve cover looks like GMC.
From 2nd series 1955 through 1959 GMC trucks with V8 engines used Pontiac V8s in the smaller trucks and Oldsmobile V8s in the larger trucks. These engines were based on same year Pontiac and Olds engine, but had (typically lower) compression ratios, different carburation and sometimes different cylinder bore sizes. All engines came from the factory painted red with GMC stickers on the valve covers. All were advertized within 1 cubic inch of the Pontiac & Olds brethern except for the 58/9 Pontiac-based engines which had smaller diameter cylinder bores.
Attachment shows the advertized engine sizes. The 500 and below models used the Pontiac-based engines while the 550 (like this fire truck) and larger models used Olds-based engines.
The '58 and '59 Pontiac based engines were both advertized as 336 cubic inches. But the '58 Pontiac crankshaft had a 3.5625" stroke with 2.623" main journals while the '59 Pontiac crankshaft had a 3.75" stroke with 3" main journals. Both the GMC engines came with smaller (but different) bores. The '58 engine was actually 336.1 cubic inches and the '59 is 336.66 cubic inches.
Here's some added details from a couple of sources on the '58-'59 "555" Series Truck (see link and screenshot below)
1958 GMC Full Line Dealer Pamphlet
~ Dan
1951 Chevy 3 window 3100
1 Offline
Didn't the 58 and 59 have dual headlights?
I don't think so on the big trucks. The 1958 "comic book" style owner's manual that came in the glove box shows a pickup with 4 headlights and a larger tractor rig (with unknown model number - shown in blue in the upper right corner of the picture below) with 2.
Kenneth Crenwelge (GiantMountainClimber) will know for sure.
The 1958 dealer pamphlet that Dan posted above also shows a tractor/trailer rig with just 2 headlights.
1 Offline
This is from the 1958 information posted above. It is on page 27 under electrical.
As noted, the dual headlights only are listed for Models 100-370 trucks (which does not include the P-Series panel trucks). The bigger truck models 450 through DW970 (including this 550 Series fire truck), were all equipped with single headlights on each fender as 4 headlight model distinction did not carry over to the bigger truck models.
~ Dan
