5 members (klhansen, TUTS 59, papas52, 78buckshot, 1 invisible), 91 guests, and 2 robots.
Topics128,186
Posts1,057,308
Members48,468
Page 2 of 2 1 2
Neither will lock from the inside.
On my '52 (with push button outside opening on one side only) I bought a new push button lock and put it into the handle that needed a lock on the outside. Had a locksmith redo the pins in the new lock mechanism to match the original lock on the other side push button.
I don't remember the details on turn down handles with separate locks (pre-52), but I have a friend that has a '50 GMC with Altman latches. I know he can lock either door from the outside. I can call him for details tomorrow if you'd like me to.
Donald S.
Donald S.
Yep, that’s what I figured. I did the same on my 53 and had the key lock for both sides.
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
Donald S.
Donald S.
UT OH!! And I thought I was done with major sheet metal work. They must have had a leak at the top of the windshield that ran down that corner and rotted all the way to the radius. The good news I can buy that part.
Drivers side corner
Passenger side corner
1953 Chevy 5-window
U
U Offline
That's why I was thinking about getting a new rubber windshield gasket. The old one is hard as rock and probably brittle.
~ John in Utah
Here We Go
Follow in his DITY Bay
Donald S.
Donald S.
Got my 4.3 back from the engine builder and since I am a sheet metal guy but not an engine builder I decided to have that done. Can’t wait to get it back on the frame to at least hear it run.
4.3 V-6
1953 Chevy 5-window
Donald S.
Donald S.
Been dividing my time between the rusted windshield area and reassembling the front of the engine so I can get the serpentine belts back on to crank it up. Next is the water pump as soon as I get the gaskets. I am not putting headers but stock exhaust manifolds that I have to clean up and paint with high temp paint. As far as the rusted a pillar and the area across the bottom I have most of that repaired. The inside corner radius was fun, but I made a nice corner template of heavy card stock to assure the fit. Last part to do is actually the upper corner of the dash. I will get a picture of it next week. I do have a couple pinholes at other locations along the windshield area that I need to check out and fix. These are not nearly as bad.
4.3 engine
4.3 engine
A pillar rust repaired
Bottom of windshield area
1953 Chevy 5-window
Donald S.
Donald S.
I know I said early on that the wife would be involved and she has. She has decided on a paint color that we saw while at SMN in Townsend. The burb may end up two tone with some pearl white from the bottom of the windows up. We’ll see. I may look for an app that can add these colors to easily visualize it.
Paint color
1953 Chevy 5-window
Donald S.
Donald S.
So I got the bottom radius corner of the windshield frame rebuilt on the drivers side and doing the PS, it wasn’t as bad.
Windshield Frame DS
PS tacked together
1953 Chevy 5-window
Good work! If the driver's side was worse than the passenger's, then it was pretty bad. But you've done a great job in fixing both. Fortunately my windshield area wasn't bad at all. I went back and looked at your previous pics and that was pretty ugly.
Donald S.
Donald S.
So…. Today I found a new spot that also needed repair. My original plan was to weld up the unused holes across the bottom of the dashboard. Half of the bottom front edge under the glove box had bondo and primer. I cut it out and partially welded the new metal back in.
Bottom of glove box repair
1953 Chevy 5-window
U
U Offline
I really appreciate those that have metal skills. Although no one might see that, the repair looks great. Just wondering how that rust happened? Was it water running down from the corner of the windshield?
~ John in Utah
Here We Go
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
It's to bad your not closer, I would trade an engine build for some metal work...
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Donald S.
Donald S.
I would have taken that deal. Just got the 4.3 back for the cost of a V-8. 🤣. Honestly the price wasn’t bad, I had him supply a bunch of extras, carb, little cam, distributor and intake. Oh well I don’t feel like I can do it all.
4.3 V-6
1953 Chevy 5-window
Donald S.
Donald S.
A couple of days work here, got the bottom of the glove compartment done all ground flush and fixed. Plugged seems like 30 more holes under the dash and a few other pinholes and over ground thru spots. I pulled the front fenders out that the PO did some work on and found the flanges on both where they hit the cab rusted out. Cut those out and tack welded a new flange in place. Weld and grind them tomorrow. I wire brushed everywhere I could get inside the cab so I’m pretty much done with the inside. I decided to go ahead and spray a couple of coats of Eastwood encapsulator on the floor, up the kick panel, firewall and under the dash. Before carpet on the floor, my interior plan is to install the 3 boxes (from the PO ) of Killmat soundproofing everywhere I can. I used a similar product on my 53 and am happy with the sound deadening properties, especially opening and closing the doors.
Front render flanges
Flanges tacked in
Inside cab painted
Glove box frame done!
1953 Chevy 5-window
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I have been showing a friend your progress, he has zero motivation (not self winding). He was impressed, and should be.
I built him a nasty 292 some years back and it's still setting on the engine stand. He really liked the idea of a 4.3L.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Donald S.
Donald S.
Yep, I got a buddy here with a 1966 Goat that I can’t get to either move it forward or get rid of it. He is like more than half way done but put it down yrs ago. He needs the room in his shop.
1953 Chevy 5-window
Donald S.
Donald S.
Well I decided to document the sheet metal completion with a picture of the burb. Doesn’t look much different from when I brought it home. It definitely is!! Ha ha , a lot of hours. I moved to fixing all the rust on the fenders. I stripped the inside of the first rear fender removing undercoating, paint all the way to metal using a wire brush then lightly ran a DA sander with 120 paper. I am going to coat the insides with rust oleum rusty metal primer then do spray-on bed liner. Been researching running board patches verses replacement. It appears new metal replacements are not available. I only need the passenger side. The drivers side is definitely salvageable. I am checking into to splicing the back half of the truck running board, still checking unless someone has already done it?
Sheet metal work done
Rear inside fender in rustoleum
1953 Chevy 5-window
AD Addict & Tinkerer
Lookin’ good Donald! Great work!
Phil
Project Journals
Stovebolt Gallery Forum
Donald S.
Donald S.
Finished doing both front fenders the same way as the rear. Time to tackle the doors, overall they don’t look too bad. Had to remove the upper clamshell curved glass. The PO had worked and cleaned them up some.
Clamshell upper door
Lower, DS and PS doors
1953 Chevy 5-window
Donald S.
Donald S.
So I finally did some physical comparison of the burb running boards compared to the trucks runnings board in hopes that I could use the pickup version as a patch for the burbs. Nope, so I ordered a patch panel from Jim Carter, maybe I can get enough of the bad out.
1953 Chevy 5-window
How bad are your running boards? Mine had wear thru and rust holes on top of most of the ribs so I used up a ton of welding wire closing them up. I also needed to replace the mount brackets and longitudinal reinforcement (available from Jim Carter.) It was lots of work, but I got it done, and covered up the blemishes with bedliner coating. This was before I knew that patch panels were available or I would have gone that route. It was also before a came across another frame with running boards, so I have a spare driver's side board. The passenger side on that was too far gone to be usable, but it yielded a patch that went to a fellow stovebolter.
Page 6 of my Flickr photo collection shows the restoration process of the running boards.
Donald S.
Donald S.
They probably aren’t that bad but have a lot of pitting and some thru holes scattered cross about 30” on the passenger side. You can see in the lower running board attached picture left end. Once I clean the PO primer and rust off and patch. I will probably fill the pits with metal set
1953 Chevy 5-window
Those look nearly pristine compared to mine. LOL! Those pit should be easy to patch.
Donald S.
Donald S.
Kevin, yes honestly they aren’t too bad. I have fixed way worse sheet metal already. I think the individual holes I will do like you did and probably weld them up and replace the larger rust thru spots with new metal. It may be a little while before I get back to them, out of town for now then need to look over the 53 to get ready for Cruisin the Coast that will occupy the first week in October. I will try to squeeze some time on them before Cruisin.
1953 Chevy 5-window
Donald S.
Donald S.
Worked on several items today. I needed to verify both of the rear fenders fit because I had slightly different dimensions at the rear of the body patches that were already done by the PO. They were PGE. I started cutting on the running board after getting my patch panel from Jim Carter. After wire brushing many bad spots I think it is going to require blasting to get a clear picture.
Fender fits.
1953 Chevy 5-window
Donald S.
Donald S.
Worked on the upper clamshell door while waiting for my sandblasted running boards to get back. Not too bad. A few pinholes and part of the original metal was cut off by the door latch. Not sure why it was modified but I put it back on. I will mount the doors to test fit them. Probably not necessary since all is original but I’ll feel better. I also got to the lower door and worked on the back of it most of today with 2 patches at the bottom on one side and a few pinholes on the other side. The front of the other side was bondoed over, when I cleaned it off a patch is needed here too.
Cut out at lock area
Repaired lock area
Lower door repair
Lower door repair
Lower door patch
1953 Chevy 5-window
Donald S.
Donald S.
So today I finished the patch on the front of the lower clamshell door. Started looking at the DS/PS doors. The outside didn’t look too bad but has just a few pin holes. The inside is a different story. Both rusted inside bottoms looked similar. Picture below.
Door inside bottom.
1953 Chevy 5-window
Donald S.
Donald S.
Got the engine and transmission mounted on my frame. Plus got most of the rust repair on the burb body, fenders and clamshell doors. Moving on!!
4.3 and 4L60E mounted
1953 Chevy 5-window
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
ZOOM ZOOM...
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Lookin’ Good!
Phil
Project Journals
Donald S.
Donald S.
I started working on the inside doors to remove the bad rust after I received the patch panels for both doors.
Door replacement patches
1953 Chevy 5-window
Donald S.
Donald S.
Almost done the 2nd door too. I decided to remove the bottom hemmed flanges that hold the inner door panel patch on. They were pretty rusted and partially gone. Added a new flange and welded all 3 edges together.
Door patch panel repair
1953 Chevy 5-window
Donald S.
Donald S.
Got my patch panel for the ugly running board. Both running boards back from the sandblaster. Cut the worst part out and used the full length of the patch. Still had to fill quite a few pin holes, Oh well, better than it was.
Went Tuesday long distance to pick up a ZR2 rear end from a 2002 s-10 to put in place of the existing s-10 rear end. The tire mounting surface dimensions is virtually the same as the stock suburban torque tube rear end. The leaf spring purches are in the correct same location. In addition I will have rear disc brakes instead of drum brakes. I will clean it up like the frame and add new calipers, rotors and dust plates. While I’m back at this end of the frame working new leaf spring bushings will be added.
PS running board
ZR2 rear end
1953 Chevy 5-window
Page 2 of 2 1 2
Moderated by  Phak1
