0 members (), 177 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
I’m looking for thoughts on manual transmission gear oil. I have a 59 GMC with a four speed manual transmission. In looking on line I understand GL-4 oils should be used rather than G-5 to avoid corrosive aspects of certain GL-5 oils. One apparent popular gear oil is Sta Lube gear oil, which is available at my local NAPA but it seems pretty pricy at $75.99 a gallon.
https://www.napaonline.com/en/search?text=Sta%20lube%20&referer=v2
Does anyone have other less pricy recommendations? Thanks for your help and guidance.
O Online: Content
What does the shop manual call for? If it's the same as AD trucks, use 90 weight mineral oil for Ford tractor transmissions.
Available at Tractor Supply.
1950 Chevrolet 3100 (Ol' Roy)
I've been using 90w GL-3 in my '52 GMC with the same SM-420 transmission as your '59 for 45,000+ miles. No telling what was in it when I got it. Autozone has it for $11/qt.
I use the “Travelers” Brand for ford tractor transmissions available at Tractor Supply and it is reasonably priced. Same as previously mentioned. Sta-Lube is too pricey. I have used it also in the past, so I believe it is a good product but the other is easier on my wallet. I believe it is sold in 2 gallon containers. Just don’t tell your GM products what is is made for and they won’t know the difference.
I invest my money in precious metals, mostly rust!
I use NAPA Sae Mineral Gear oil 90W. Sells for $56.99 / gal.
Craig
7
7 Offline
Go to the Valvoline site, manual transmission lube.
Wow, thanks for all of these suggestions. I’ll see which one is easiest to get locally. This is very helpful and much appreciated.
FYI, I ended up going with the “Travelers” brand from Tractor Supply. It was available locally and priced well. So far so good. Thanks again for all of the great suggestions! Much appreciated!
