2 members (DadsFirstPickup, Stovebolt48), 97 guests, and 1 robot.
Topics128,050
Posts1,055,670
#1608 02/01/2002 11:21 PM
Whats the differance in these two transmissions? Whats the pro's and con's also. Thanks! cool
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
V
V Offline
700R4 is the same thing as a 4L60E, they just use a new name, plus it is electronically controlled (the meaning of the E in the name). 4L80E is the TH400 with an overdrive gear on it. You can think of the 700R4 (or 4L60E) as a TH350 with an overdrive gear. It's an oversimplification, but it makes it a lot easier to understand for most people.
Use the 700R4 for most applications. IF you REALLY do a lot of towing or have a heavy vehicle use the 4L80E.
Vaughn is right,except that with the 4l80E you will need a computer. The computer controls shifting through solenoids instead of mechanical valves as in the TH350/400 and 700R4.
The 700R4 uses the computer to control the Torque convertor lockup, but you can buy an aftermarket kit to by pass that function. The 4l80E was designed to work with a computer.
Be sure you get a later model 700R4 if you go that route. The early ones (86-88) were known as the Turbohandgrenade for a reason
4L80E is suppose to be a really stout tranny, and it is the conversion that a lot of people are going.
however, it is also an expensive route to go. the tranny isn't cheap, and then it has to be computer controlled.
you can get the raptor which is a 700r4 that allows towing in OD, and also is guarenteed up to 600 HP for around $1500. an expensive 700r4, but when you consider what this tranny will handle I think it is a pretty cheap option.
May the force be with you - SoloWookie
solowookie.com
Which models come in the 1/2 ton pickups for light duty?
Which models are in the 3/4 ton and above for heavier duty applications?
THat's where I'm confused.
Jay
People don't understand why I love old trucks...could it be cause i'm 17?
'54 3800 dually
http://www.dpsolutions-inc.com/54truck/truck.jpg
'56 GMC Dump Truck (and story)
http://www.dpsolutions-inc.com/56dump
Anonymous
Unregistered
Anonymous
Unregistered
4L80's and 4L80E's have a GVW rating of 15,000 lbs or more depending on clutch packs used - 3/4ton and 1ton trucks have these trannys and they will also go behind Duramaxes in 2002 burbs. Much stouter than the 700R4's which are considered light duty trannys. I have had several people tell me that the computer interface for the 4L80"E" is not that tough to figure out. You can buy a programmable "smart" relay with 16 digital I/O and 2 analog inputs that could manage the function for under $100. Here is a decent link someone else posted a few months ago that clear up some of the questions about GM trannys, ratings, etc. tranny link
