9 members (Gdads51, 52Carl, Stewart2, Gray_Ghost, Canadian Dump, KEVINSKI, Otto Skorzeny, Southerntruck, BC59),
184
Mod | | | Forums66 Topics128,165 Posts1,057,006 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Hi, I have a 59 235 block, installed a sealed power hydraulic, cam CS-323, and Lifters HT-817. Upon installing I notice the lifters don't fit as good in the bores as I thought they are supposed to. I tried to post a video to show but the system only allows 5mb files. The lifters wobble around in the bores and this doesn't seem right. any help appreciated.
Still trying to get ole Betsy back on the road.
| | | | | Joined: Sep 2009 Posts: 5,989 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,989 | Craig - In doing a quick search on the web, my search results indicate you need HT-761 lifters (0.989 to 0.990 inches diameter) for a '59 235. HT-817 specs indicate those are 0.842-inch diameter, which is the standard diameter for Chevy small block and later 230/250 inline 6's. It's the right cam for 235/261 engines, but the wrong lifters.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 | First thing to decide is are the new lifters the right size. I don't have any 235 specs, but just for example the '59 GMC Maintenance Manual lists bore size of .9905 to .9915 inches and lifter diameter of .989 to .990 inches for new parts. That would give a new part clearance of .0005 to .0025 inches. Maximum wear clearance is listed as .004 inches.
You need to find the same specs for your Chevy.
EDIT:
Dan beat me to the draw.
Looks like Chevy and GMC 6 cylinder engines may have used the same lifters (or at least the same diameter - the GMC uses solid lifters) in '59.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | There are two kinds of cams and lifters for stovebolt engines- - - -solid- - - -and WRONG! Good luck trying to keep those lifters pumped up and quiet- - - - -there's an astronomical failure rate on hydraulic lifters made for stovebolt engines in the past 30-something years. Jerry
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Thanks Dan, Now if I can just find a set
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Gotcha, but I wanted to try it any way. Its a spare engine from left over parts. I have three with solids so I know what you mean.
| | | | | Joined: Sep 2009 Posts: 5,989 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,989 | Craig - Here are two hydraulic lifters being offered at Summit Racing. The first is from Kanter and second is a Melling sourced part. Both indicate being available. Jim Carter offers ME991 235 Hydraulic Lifters at a price similar to the Melling's from Summit. Prices are what they are - ugh!
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | It's also possible to put thinwall sleeves in the lifter bores, and run the available (and affordable) Ford/AMC/MOPAR lifters. Modified pushrods are required, however. Jerry
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Thanks for the information and links. I'll probably go with the Kanter due to price. I can't believe what they want for these. I suppose they deliver from first national bank trust dept.
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Hi Jerry, Nice to know there is an option as some day there won't be parts available. Some of the websites for parts are staring to list nothing older than about 1980.
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | I've got a 216 block modified that way- - - - -one that I was considering fitting with a roller cam, using lifters for a big block MOPAR V8. I just can't get any of the custom camshaft grinders to try to make a cam for me. I even offered to machine my own cam core for them to whittle on- - - - -"not interested"! Jerry
| | | | | Joined: Oct 2021 Posts: 6,940 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,940 | Craig, do a lot of research before buying from Kanter. They have a really bad reputation for junk parts among the Cadillac community and specifically among those who actually drive their vehicles.
Lifters, rockers, springs are crap. My engine builder will NOT use Kanter's engine stuff at any cost.
Steering and suspension components are weak. Leaf and coil springs sag in a year or two. Anything they sell made of rubber will disintegrate while you watch.
I have seen restoration projects still in the garage with brand new rubber bushings, etc that have never been on the road but have fallen apart while the project is on stands.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | thank you for the info. I don't need any more problems than i already have.
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | WHATS WITH THE HIGH DOLLAR PRICES?  $47 bucks for one stinkin lifter
| | | | | Joined: Sep 2019 Posts: 165 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 165 | Good grief! That’s twice what the Buick straight eight hydraulic lifters go for. I always thought Chevrolet parts were cheap and plentiful. Let me look in my stash of stuff and see what I have. If I have any they will be from a ‘62 passenger vehicle. Same engine as the head that I have listed. And matching cam.
I invest my money in precious metals, mostly rust!
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Great let me know if you find some
| | | | | Joined: Sep 2009 Posts: 5,989 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,989 | Craig and Rusty - Just a reminder to take further conversation on this topic that involves actual buying/selling to PMs as those conversations aren't allowed in the "Shop Area Forums". Thanks.
| | | | | Joined: Sep 2019 Posts: 165 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 165 | PM sent. Thanks Gdad!
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Gotcha, Thanks for the reminder
| | | | | Joined: Jun 2018 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 95 | As an add on... I sent my lifters ('55 solid) to rocker arms unilimeted to be resurfaced. Quoted $6 per lifter. Will be a bit before they return so I'll let you know how things go when they return.
1954 3600 Stakebed non-original engine out of a '55 passenger car with powerglide
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | MOPAR lifters are .904" diameter, compared to .990" for stovebolt lifters. It's easy to make a reducer sleeve from 1" seamless steel tubing, swage it into place, and do a final diameter fit with a carbide button ("dingleberry") brake cylinder hone. A set of 16 solid lifters for a big block MOPAR engine costs about $75.00, and a very simple modification to the pushrods allows them to be used during an engine overhaul, along with a new camshaft. www.ebay.com/itm/150812619057?Jerry
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Oh if I just had those skills 😁
