7 members (Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51, mick53, Gdads51),
128
0
Mod | | | Forums66 Topics128,109 Posts1,056,267 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | My '53 Chevy 3600 with stock 4 speed transmission, stock 4.57:1 rear end and 15" wheels has never read the speed correctly on the speedometer. It is consistently 6-7 mph over the actual speed. I think the wrong speedometer gear was installed in the factory and it has a gear for 17" wheels instead of 15" wheels. What would be the best way to correct this or am I thinking wrong about it? I don't want to change out the wheels and tires just to make the speed read correctly.
Chris
G.O.T. (Good Ol' Truck), 1953 Chevy 3609 AD 3/4 ton with original 216 c.i. engine, 4 speed transmission, stake bed
| | | | | Joined: Jan 2022 Posts: 2,459 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,459 | If it is "consistently 6-7 mph over" it isn't a gearing problem. A gearing problem would be X mph over at 15 mph, 2X at 30 MPH, 3X at 45 MPH and 4X at 60 MPH.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Get a speeometer adapter from vendors like Jim Carter Truck Parts? Pretty easy instructions to follow: https://oldchevytrucks.com/sp249.html
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | Thanks Craig, that does look pretty easy. I suspect using a GPS speedometer to get the true speed would be accurate enough.
Chris
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Yes, I use an AP called speedbox. I let the wife tell me what it is saying while I'm driving and looking at the truck's speedo.
| | | | | Joined: Jan 2022 Posts: 2,459 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,459 | Woodcmiami
At what speed is it "consistently 6 - 7 mph over"? How far over is it at twice and half that speed?
| | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | When it is cool enough to drive I will test it at those speeds. It reads about 41 mph when I am going 35.
Chris
| | | | | Joined: Jan 2022 Posts: 2,459 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,459 | Changing the speedometer gearing will solve your problem if your test results are something like this:
actual MPH ......... 20 25 30 35 40 45 50 55 60 speedometer reads 23 29 35 41 47 53 59 64 70
You've already done the 35 MPH test, just do two more, maybe 25 MPH actual and 50 MPH actual.
| | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | Thanks, it really doesn't like to go 50 mph so I will try 25 and 45 mph.
Chris
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | First lesson of the day, speedometer needles are magnet driven, odometers are gear driven. The magnet can be dirty or weak and make the speed wrong. Odometers are gear driven off the cable and gears. Tire size, rear axle, and speedometer gears will change the odometer. Odometer should be corrected first, then address the speedometer. Drive ten miles at a steady speed on a marked highway and write down the mileage shown compared to marker signs. Adjust gears or add adaptor to correct the odometer. Speed doesn't matter to the odometer. https://www.speedoservice.com/speedometer-calibration/ These guys can fix you up with parts or service. Speedometers / odometers are calibrated to 1000 rpm cable = 60 mph.
| | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | thanks, I plan on checking the accuracy of the odometer and speedometer when the weather breaks in a couple of weeks. It is going to be 107 F today, too hot to sit in a metal truck cab!
Chris
| | | | | Joined: Jan 2022 Posts: 2,459 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,459 | Joe is right in saying the odometer test will tell you if the "gearing" for the speedometer is right. Do the "10 mile" test he recommends, but keeping a "steady speed" is not necessary. Drive ten miles at a steady speed on a marked highway and write down the mileage shown compared to marker signs.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Joe and Bill, Good info. So many of us just look at the speedo and not the odometer for their accuracy. Time for me to put down my "Honey Do" list and take the truck out for a 10 mile odometer test spin.
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | There is a way to check it on your driveway, I will see if I can post it when I get home today. You mark out a distance on the driveway and roll the truck for 1 speedometer rotation.
Its 1000 cable rotations per mile. So you have to take in account the gear ratio and tire diameter.
Add A/C, it helps setting in the oven! | | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | Not going the A/C route in that old truck. Everything is original mechanically and I intend it to stay that way. I was wondering if the odometer does end up reading wrong because of the wrong gears then does that means the actual mileage would be wrong too? I have had it for 37 years and it started with 16K miles and now has 32K. I guess I could calculate the actual mileage once I figure out what the error is.
Chris
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | How to check speedometer with out driving ( far ). A helper to count would be helpful.
Unhook cable end at speedometer head and pull out from under dash so you can see it, wrap a piece of tape around end as a flag.
Mark out 52' - 9 1/2" on a flat surface,
Roll up to the starting mark on the ground, place tape on the truck with mark to accurately align with the mark on the ground. I used a plumb bob.
Roll forward while counting turns of the cable till you travel the full 52' -9 1/2".
If it's geared right, the cable will rotate 10 times.
Repeat a couple times to verify the results.
| | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | Joe H, You put 52'-9 1/2" then 52"- 9 1/2", can you clarify this?
Chris
| | | | | Joined: Jan 2022 Posts: 2,459 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,459 | 52 feet 9.5 inches is 1/100th of a mile.
If Joe is right about 1000 revolutions of the speedo cable to be a mile (I'm not arguing, I just don't know) the cable should turn exactly 10 times. If 9 1/2 times then the speedo will be 5% slow. If 11 times the speedo will be 10% fast.
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | Bill is right, I typed it wrong and went back and changed it. I found the information back in 2001 from a now closed speedometer shop. | | | | | Joined: Jun 2021 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 60 | Got it, that makes sense.
Chris
