4 members (NJC, Otto Skorzeny, Wally / Montana, 2-Ton), 66 guests, and 3 robots.
Topics128,263
Posts1,058,134
Members48,482
Anyone have experience troubleshooting and replacing the backup switch in a 1966 C10 with 3-speed transmission? My truck has been… modified. Some previous owner installed a toggle switch. In looking online I’m not seeing what I expected to see. Thanks!
Professional Novice
Lmc seems to have the switch ,looks like it goes on the steering column
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
The switch Kevinski pointed out is correct, presuming you still have the 3 speed column shifter on your truck. If your truck got modified by the PO with a floor shifter, that takes the column switch out of the equation.
Yes, still column shifter, or no? headscratch
~ Dan
1951 Chevy 3 window 3100
Sorry I have been so long getting back to this! Life… you know. Thank you Kevinski and Gdads51. Yes, still 3-speed on the column.
Professional Novice
Socket Breaker
Socket Breaker
Yep. I am not sure how many models/year run they did that, but there was that half donut horse shaped thing that sits on the column, above the floor and it rotates as you shift.
