3 members (Guitplayer, 2Wheels, 1 invisible), 161 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,469
#1609574 08/16/2026 4:44 PM
I just noticed that the serrated rectangular nuts for holding the striker in place are missing on one side of the cab. They may been lost when It was dipped. Are these still available, I have not found them in the retail market. What have you guys used for these in place of the original?
Shade Baby
3104
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
I don’t know if these are available in the aftermarket, but they wouldn’t be hard to make. Or a want ad would possibly prompt a fellow bolter to provide one.
Ok, Thanks
Shade Baby
"Back In Time"
Follow in the DITY
A little late on a response, but I was missing one side while pre-assembly a few years ago. I found a seller on eBay but was out of stock. I ended up finding used locally. eBay seller might have them again, don’t know.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
Can someone provide a pic of one?
Craig
Here's a picture of a couple of later 1960-63 NOS GMC latch strike plate kits (courtesy of Brad Allen) that includes the serrated anchor plates (circled in red in snapshot below) among the parts that make up the complete kit.
~ Dan
1951 Chevy 3 window 3100
Just a thought, but you could probably make replacement threaded serrated nut plates from some flat stock easier than findings originals. The above 1960-63 kits, which you can still find on ebay, are slightly different from the AD series serrated nut plates.
The 1960-63 serrated plates do not have threaded holes, but work with the smooth flat plates (below and right of the serrated plates) that have the threaded holes which sandwich the flat nut plate, serrated plate, cab panel and strike plate to lock in place when the hardware is tightened.
~ Dan
Digging a little deeper in Brad Allen's "Parts" pictures, I believe the serrated rectangular threaded hole nut plates in the upper center/right box in this AD parts bin2 picture (see zoomed in screenshot below) are the correct ones for the AD series truck door strike plates.
~ Dan
Here's a couple pics of mine when I was drilling out a broken bolt and retapping. The vise in the pic has 3-1/2" jaws for scale.
Thanks, I know just what to do.
Shade Baby
"Back In Time"
Follow in the DITY
