8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 23 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 23 | I recently had straight axle lowered 3 inches. Front springs are on back order and cannot reach person that did the axle for advice, so reaching out to you all with experience. Since axle was modified with 3 inch drop, what springs can be used up front? I see that LMC sells a 3 inch lowering spring set, but will that put front end even lower? I dont want truck too low, 3-4 inches ideally. Thanks. '53 3100 truck.
53 chevy 3100
| | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | Just IMHO, but using those LMC "lowering springs" is going to drop your front end into the weeds.  You've already achieved a 3" drop with the modified axle, so I'd stick with stock height springs to not lower it any further. I'm sure others will chime in with their thoughts/experiences in a bit.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Which is cheaper? 3" drop on axle or 3" lowering springs? Which is easier to do? Seems you would get same results. Asking for a friend.
What is the deal with the original springs? If you only want a 3" drop, you accomplished that with the axle work. Go back with standard springs if you need to replace the originals. JMO
Regards
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
