5 members (Wally / Montana, 55shaker, MikeStone1953, Gdads51, Bruce 1954-4100), 113 guests, and 3 robots.
Topics128,109
Posts1,056,253
Members48,437
#1609445 08/14/2026 12:30 PM
I
I Offline
I recently had straight axle lowered 3 inches. Front springs are on back order and cannot reach person that did the axle for advice, so reaching out to you all with experience. Since axle was modified with 3 inch drop, what springs can be used up front? I see that LMC sells a 3 inch lowering spring set, but will that put front end even lower? I dont want truck too low, 3-4 inches ideally. Thanks. '53 3100 truck.
53 chevy 3100
IHPWR #1609446 08/14/2026 12:37 PM
Just IMHO, but using those LMC "lowering springs" is going to drop your front end into the weeds. drive You've already achieved a 3" drop with the modified axle, so I'd stick with stock height springs to not lower it any further.
I'm sure others will chime in with their thoughts/experiences in a bit. wink
~ Dan
1951 Chevy 3 window 3100
Which is cheaper? 3" drop on axle or 3" lowering springs?
Which is easier to do? Seems you would get same results. Asking for a friend.
What is the deal with the original springs? If you only want a 3" drop, you accomplished that with the axle work. Go back with standard springs if you need to replace the originals.
JMO
Regards
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
